585,937 active members*
3,877 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Tool Change - Can I set it to auto stop?
Results 1 to 17 of 17
    inthezone Guest
    I'm not sure if this is an error in my software, or my Fanuc Controller...
    When I am going in for a tool change, the code issues the T command with specified tool number. I am having to manually stop the program, and turn off the spindle to change the tool. If I wasn't watching the program closely, the program would simply continue on its happy way with the wrong tool. Very dangerous.
    I am used to having the program stop the machine, and turn off the spindle for a tool change, and then having to press "cycle-start" in order for it to continue.
    Is this something that has to be programmed into the controller, or is it something I can issue up in my code?
    Feb 2007
    464
    Post an example of the program.It makes it easier to see what's wrong.
    24221
    Sounds like the PMC is not programmed to recognizing the T code, normally it is done to do the change automatically or if a manual tool change machine, then a stop is issued with a message and then wait for cycle start.
    If it was originally programmed for automatic tool changer then there may be a sensor malfunction etc.
    Al.
    Albert E.
    inthezone Guest
    :Microscope Switch-out
    (8-2-2007)
    N25G00G17G40G49G80
    N30G30G91Z0
    N35T2M6
    N40G00G54G90X18.62435Y8.1577S3000M03
    N45G43H2Z-9.5
    N50Z-9.5558
    N55G01Z-9.6458F9.0
    N60X18.80185Z-9.6605
    N65X18.62435Z-9.6753
    N70X18.80185Z-9.69
    N75X18.62435Z-9.7047
    N80X18.80185Z-9.7195
    N85X18.62435Z-9.7342
    N90X18.80185Z-9.749
    N95X18.62435Z-9.7637
    N100X18.80185Z-9.7784
    N105X18.62435Z-9.7932
    N110X18.80185Z-9.8079
    N115X18.62435Z-9.8226
    N120X18.80185Z-9.8374
    N125X18.62435Z-9.8521
    N130X18.80185Z-9.8669
    N135X18.62435Z-9.8816
    N140X18.80185Z-9.8963
    N145X18.62435Z-9.9111
    N150X18.80185Z-9.9258
    N155X18.7186F18.0
    N160G03X18.7186Y8.1577I-0.0055J0.F12.6
    N165G02X18.76023Y8.1577I0.0208J0.F18.0
    N170G03X18.80185Y8.1577I0.0208J0.F12.6
    N175X18.80185Y8.1577I-0.0887J0.
    N180G01X18.81377Y8.20651F15.0
    N185G03X18.7893Y8.2504I-0.0681J-0.0092F7.5
    N190X18.7893Y8.2504I-0.0762J-0.0927
    N195X18.69572Y8.27644I-0.0762J-0.0927
    N200X18.6521Y8.25149I0.01J-0.068
    N205G01X18.6371Y8.20353F15.0
    N210G00Z-9.5
    N215X19.45661Y9.11689
    N220Z-9.5558
    N225G01Z-9.6458F5.0
    N230G02X19.28586Y8.93536Z-9.6639I-0.7435J0.5283
    N235G03X19.45661Y9.11689Z-9.682I-0.5728J0.7098
    N240G02X19.28586Y8.93536Z-9.7002I-0.7435J0.5283
    N245G03X19.45661Y9.11689Z-9.7183I-0.5728J0.7098
    N250G02X19.28586Y8.93536Z-9.7364I-0.7435J0.5283
    N255G03X19.45661Y9.11689Z-9.7546I-0.5728J0.7098
    N260G02X19.28586Y8.93536Z-9.7727I-0.7435J0.5283
    N265G03X19.45661Y9.11689Z-9.7908I-0.5728J0.7098
    N270G02X18.96673Y8.76907I-0.7435J0.5283F10.0
    N275X18.45947Y8.76907I-0.2536J0.0887
    N280X17.96959Y9.11689I0.2536J0.8761
    N285X17.68746Y9.39339I0.0821J0.3659
    N290X19.73874Y9.39339I1.0256J0.2518
    N295X19.45661Y9.11689I-0.3642J0.0894
    N300X19.28586Y8.93536Z-9.8077I-0.7435J0.5283F5.0
    N305G03X19.45661Y9.11689Z-9.8245I-0.5728J0.7098
    N310G02X19.28586Y8.93536Z-9.8414I-0.7435J0.5283
    N315G03X19.45661Y9.11689Z-9.8583I-0.5728J0.7098
    N320G02X19.28586Y8.93536Z-9.8752I-0.7435J0.5283
    N325G03X19.45661Y9.11689Z-9.892I-0.5728J0.7098
    N330G02X19.28586Y8.93536Z-9.9089I-0.7435J0.5283
    N335G03X19.45661Y9.11689Z-9.9258I-0.5728J0.7098
    N340G02X18.96673Y8.76907I-0.7435J0.5283F10.0
    N345X18.45947Y8.76907I-0.2536J0.0887
    N350X17.96959Y9.11689I0.2536J0.8761
    N355X17.68746Y9.39339I0.0821J0.3659
    N360X19.73874Y9.39339I1.0256J0.2518
    N365X19.45661Y9.11689I-0.3642J0.0894
    N370G00Z-9.5
    N375X19.6331Y6.6702
    N380Z-9.5558
    N385G01Z-9.6458F5.0
    N390G02X19.59934Y6.42327Z-9.6639I-0.92J0.
    N395G03X19.6331Y6.6702Z-9.682I-0.8862J0.2469
    N400G02X19.59934Y6.42327Z-9.7002I-0.92J0.
    N405G03X19.6331Y6.6702Z-9.7183I-0.8862J0.2469
    N410G02X19.59934Y6.42327Z-9.7364I-0.92J0.
    N415G03X19.6331Y6.6702Z-9.7546I-0.8862J0.2469
    N420G02X19.59934Y6.42327Z-9.7727I-0.92J0.
    N425G03X19.6331Y6.6702Z-9.7908I-0.8862J0.2469
    N430G02X19.6331Y6.6702I-0.92J0.F10.0
    N435X19.59934Y6.42327Z-9.8077I-0.92J0.F5.0
    N440G03X19.6331Y6.6702Z-9.8245I-0.8862J0.2469
    N445G02X19.59934Y6.42327Z-9.8414I-0.92J0.
    N450G03X19.6331Y6.6702Z-9.8583I-0.8862J0.2469
    N455G02X19.59934Y6.42327Z-9.8752I-0.92J0.
    N460G03X19.6331Y6.6702Z-9.892I-0.8862J0.2469
    N465G02X19.59934Y6.42327Z-9.9089I-0.92J0.
    N470G03X19.6331Y6.6702Z-9.9258I-0.8862J0.2469
    N475G02X19.6331Y6.6702I-0.92J0.F10.0
    N480G00Z-9.5
    N485G30G91Z0M09
    N490G49G90
    N495M01
    N500T5M06
    N505G00G54X18.7131Y9.6452S401M03
    N510G43H5Z-9.5
    N515Z-9.5558
    N520G01Z-9.6458F1.4
    N525X19.4631Z-9.7758
    N530X18.7131Z-9.9058
    N535X19.5192F2.8
    N540G02X17.907Y9.6452I-0.8061J0.
    N545G00Z-9.5
    N550G30G91Z0M09
    N555G49G90
    N560M01
    N565T3M06
    N570G00G54X18.7131Y8.1577S305M03
    N575G43H3Z-9.5
    N580Z-9.5558
    N585G85R-9.5558Z-9.9758F9.1
    N590G80
    N595Z-9.5
    N600G30G91Z0M09
    N605G49G90
    N610M01
    N615T2M06
    N620G00G54X18.36282Y11.1684S3000M03
    N625G43H2Z-9.5
    N630Z-9.5558
    N635G01Z-9.6458F5.0
    N640X18.60789Y11.11895Z-9.6639
    N645X18.36282Y11.1684Z-9.682
    N650X18.60789Y11.11895Z-9.7002
    N655X18.36282Y11.1684Z-9.7183
    N660X18.60789Y11.11895Z-9.7364
    N665X18.36282Y11.1684Z-9.7546
    N670X18.60789Y11.11895Z-9.7727
    N675X18.36282Y11.1684Z-9.7908
    N680X18.72586Y11.09514F10.0
    N685G02X20.1631Y9.6452I-0.0128J-1.4499
    N690G01Y6.6702
    N695G02X18.72586Y5.22026I-1.45J0.
    N700G01X18.36282Y5.147
    N705X18.60789Y5.19645Z-9.8077F5.0
    N710X18.36282Y5.147Z-9.8245
    N715X18.60789Y5.19645Z-9.8414
    N720X18.36282Y5.147Z-9.8583
    N725X18.60789Y5.19645Z-9.8752
    N730X18.36282Y5.147Z-9.892
    N735X18.60789Y5.19645Z-9.9089
    N740X18.36282Y5.147Z-9.9258
    N745X18.72586Y5.22026F10.0
    N750G03X20.1631Y6.6702I-0.0128J1.4499
    N755G01Y9.6452
    N760G03X18.72586Y11.09514I-1.45J0.
    N765G01X18.36282Y11.1684
    N770G00Z-9.5
    N775G54S2500
    N780F4.2
    N785X18.0881Y5.36181
    N790Z-9.5558
    N795G01Z-9.6458F4.2
    N800G02X17.8729Y5.48844Z-9.6639I0.625J1.3084
    N805G03X18.0881Y5.36181Z-9.682I0.8402J1.1818
    N810G02X17.8729Y5.48844Z-9.7002I0.625J1.3084
    N815G03X18.0881Y5.36181Z-9.7183I0.8402J1.1818
    N820G02X17.8729Y5.48844Z-9.7364I0.625J1.3084
    N825G03X18.0881Y5.36181Z-9.7545I0.8402J1.1818
    N830G02X17.8729Y5.48844Z-9.7727I0.625J1.3084
    N835G03X18.0881Y5.36181Z-9.7908I0.8402J1.1818
    N840G02X17.2631Y6.6702I0.625J1.3084F8.4
    N845G01Y9.6452
    N850G02X18.0881Y10.95359I1.45J0.
    N855G03X17.8729Y10.82696Z-9.8077I0.625J-1.3084F4.2
    N860G02X18.0881Y10.95359Z-9.8245I0.8402J-1.1818
    N865G03X17.8729Y10.82696Z-9.8414I0.625J-1.3084
    N870G02X18.0881Y10.95359Z-9.8583I0.8402J-1.1818
    N875G03X17.8729Y10.82696Z-9.8752I0.625J-1.3084
    N880G02X18.0881Y10.95359Z-9.892I0.8402J-1.1818
    N885G03X17.8729Y10.82696Z-9.9089I0.625J-1.3084
    N890G02X18.0881Y10.95359Z-9.9258I0.8402J-1.1818
    N895G03X17.2631Y9.6452I0.625J-1.3084F8.4
    N900G01Y6.6702
    N905G03X18.0881Y5.36181I1.45J0.
    N910G00Z-9.5
    N915G0G91G28Z0M09
    N920G49G90
    N925M30
    Feb 2007
    464
    N480G00Z-9.5
    N485G30G91Z0M09
    N490G49G90
    N495M01
    N500T5M06
    N510G43H5Z-9.5
    N515Z-9.5558
    So when it reach the part of the program marked red ,it just continues with the tool it has in the spindle?
    inthezone Guest
    This bridgeport series II is manual tool change only. Lemme guess, programming the PMC to stop the spindle and program during a tool change is a pain?
    inthezone Guest
    Mitsui Seiki, yeah it just continues, no pause or anything!
    Feb 2007
    464
    The M06 is usually a subprogram(macro),depending on what Fanuc control you have, that includes spindle stop/spindle orientation.Do you still have that?
    Feb 2007
    464
    Use "Optional stop" and run tool change using "Single block" and see what happens.
    24221
    M,S,T codes are typically written in the PMC ladder, it is up to the MTB or OEM to include them, especially if the machine has a tool changer.
    Al.
    Albert E.
    Feb 2006
    992
    I guess you should check Optional Stop see if it is on or maybe the switch is loose, it is sound funny....... but maybe that's all it need and check machine parameter.
    The best way to learn is trial error.
    Dec 2006
    84
    Quote Originally Posted by inthezone View Post
    You could do it a couple of different ways. 1. Create a macro as mitsui suggested, where when M6 is fired you can bring it into position for a tool change stop spindle and orient(if needed) and then issue an M0(as long as the parameters aren't set to reset/rewind off of an M0). And you may also have to re initalize any work coordinate offsets you are using depending on the parameter settings.
    O9006 (M6 Sub);
    G91G28Z0;
    M5;
    M19;
    M00;
    M99;
    Or..2. As you mentioned edit the ladder logic to stop the spindle and program. This should be a relatively easy edit if you're comfortable with getting in and making changes. If you're not comfortable with it and decide to go this route send me a PM and I'd be glad to help.
    Apr 2005
    3634
    Some code, etc...
    M5 (Spindle Stop)
    M9 (Coolant Off)
    (Might want to add a small amount of Dwell Time here)
    Change Tool,etc...
    M8 (Coolant On)
    M3 (Spindle CW)
    Some code, etc...
    M3 - Spindle CW
    M4 - Spindle CCW
    M5 - Spindle Stop
    M6 - Load Tool
    M8 - Coolant On
    M9 - Coolant Off
    Feb 2006
    338
    Your problems is that typically machines without tool changers do not include the M06 in the ladder. Check your M code list to be sure.
    Quote Originally Posted by codyst View Post
    Codyst gave a great way to handle it, making the sub/macro and assigning it to M6 is my prefered way to handle it. Aditionally you can put that code in your programs instead of using the M6 as a macro/sub if that isn't supported. I also like to add intalizing tool length comp in my M6 macros, the example only stops the spindle for you.
    Dale
    Feb 2006
    338
    Also take a look at my previous post Sample Fanuc Tool change macro
    Another post you might get something from A sample tool change macro
    inthezone Guest
    Dale,
    I am not quite sure how to look at my "M Code List" to check whether M06 is included in the ladder. What is the M Code list, and where is it located? I have lots of reference material on my controller, including the parameter manual but I am not quite sure what you mean.
    If M6 is in fact not included in the ladder, I am guessing that I have to program a macro.
    I looked at your post about a tool change macro for fanuc controllers because I have a Fanuc O-M controller on my bridgeport. That looks like what I probably need to do. In your post you mention that you have to "set parameter 6046 = 6" on your specific controller. My controller will obviously be different.
    In my parameter manual there is this line:
    -- 0040#5 ) TMCR 1 A T code is processed as the code of the tool function/code for calling 09000.
    So I am guessing that I would have to set parameter 0040 = 5, and then write my tool change macro in program O9000.
    Problem is I am not sure how to set parameter 0040 equal to 5.
    In my parameter list,
    NO. DATA
    0040 00000000
    Looking at the data, I can see that there are 8 zeros so I am assuming that this is an 8 bit system, and that setting 0040 = 5 would be like so:
    NO. DATA
    0040 00000101
    But I am making a lot of assumptions here. I am not even sure if I am supposed to set it to 5.. anyone know whats going on here?
    Feb 2006
    338
    For the M code list. Whoever put the control onto the machine should have provided some list of G and M codes that they enabled for the machine. Somewhere in the documentation they should list what is available for you to use.
    For the macros stuff I'll suggest you read up on the macro programming section of your fanuc control. I'll try to give you the information it looks like your missing, but it will not be a thorough as the manual.
    First lets clear up the parameter 0040#5
    What they are talking about is parameter 40 bit 5 There are 8 bits in parameters like that. 0 thru 7 starting at the RIGHT and each bit can be a 0 or 1 This is called binary, and each bit is a virtual on/off switch for the control.
    So the bit positions are:
    76543210
    You would need to set the on in the 5th position to 1 to turn that position on, or 0 to turn it off. LEAVE all the other bits as they were.
    If 40 was 10010010 then you would change it to 10110010
    There are of course parameters that aren't binary and take a normal number.
    Now That said setting 40#5 to 1 will turn on using program 9000 whenever a T command is used. This is similar to using M6 as a macro, and in your case can be used in place of it if you want. You will not need a M6 at in in that case. In your main program you would only specify T7 without an M6 to change to tool 7
    Regardless of the method of calling the tool change code, you still have to work out what you want it to do. Despite all the talk about macros and such, you should first make the machine do what you wish with code right in the program, then move that code to the macro to make it easier to use.
    So lets take a few steps back and start with the basics. I think in an effort to make your life easier, the suggestions of making the tool change a macro has made it harder. At a tool change you want to move the spindle to a safe point, stop the spindle and coolant, and stop the program so a manual tool change can be performed. codyst gave you a sub program that will do all that. In your program posted before replace your tool changes (M01 tool number and M06) with
    Code:
    G91G28Z0;
    M5;
    M19;
    M00;
    You shouldn't NEED anything more. Make sure that works for what you want. If so, perhaps just leave it at that.
  1. Another Aussie Auto Tool Zero Setter
    By Greolt in forum CNC Wood Router Project Log
    Last Post: 02-17-2019, 06:25 AM
  2. How to change Tool change position(About MAZATROL T1 control)
    By liushuixingyun in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-07-2014, 01:33 AM
  3. Auto tool zero
    By kentavv in forum Mach Mill
    Last Post: 10-08-2010, 05:03 PM
  4. Auto Tool Zero
    By Moondog in forum Machines running Mach Software
    Last Post: 12-23-2006, 01:02 AM
  5. 5th axis and Auto Tool Changer
    By coolman in forum Commercial CNC Wood Routers
    Last Post: 01-11-2005, 06:48 PM
