586,024 active members*
4,245 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > XY cutting problem/surface finish
    I got problem on 4020 machine
    This is finishing problem when I make a cut in straight line
    The finish is o.k.
    But when I make the cut with two axis together
    I got wavy finishing
    did somebody had problem like this
    i checked resolver-borads-gibs
    and tune amps!
    1225
    Re: XY cutting problem/surface finish
    What cutting parameters were you using?A light hobby machine can't be expected to operate at the sort of speeds and cutting depth that an industrial machine would be comfortable with.
    Quote Originally Posted by routalot View Post
    3500rpm
    .1 amount
    feed=850mm/min
    1225
    The material is?
    The material is?
    i cleaning boards and reseating all boards
    problems fixed
    cutting is ok and mirror finish obtained
  1. Hemisphere surface finish problem
    By MFchief in forum Tormach Personal CNC Mill
    Last Post: 10-11-2014, 03:34 AM
  2. X3 Surface Finish Contour Problem
    By moto1965 in forum Mastercam
    Last Post: 01-10-2012, 03:52 AM
  3. Surface finish toolpath problem in X5
    By yenchen23 in forum Mastercam
    Last Post: 12-05-2011, 06:23 AM
  4. Surface finish problem
    By gar in forum Haas Mills
    Last Post: 05-22-2008, 03:01 PM
  5. 3D Milling Surface Finish Problem
    By TurboME in forum MetalWork Discussion
    Last Post: 12-18-2006, 05:32 AM
