585,712 active members*
3,644 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Flushing Bacteria from Machine Coolant System
    Mar 2004
    205
    The VMC we have at work has a spoiled batch of coolant and I need to flush the entire system to kill any residual bacteria that is in the system or else it will just reduce the life of the new batch of coolant I add.
    Anyone have any particular additive they use that is safe for the system, but will kill all the bacteria currently in the system?
    We use Blaser coolant and I know Blaser has their Blaserclean AF, but I was hoping their was something else I could use, as Blaserclean is not cheap.
    I was hoping their might be something available at a pool supply that would kill any fungus / bacteria.
    Re: Flushing Bacteria from Machine Coolant System
    There are other cheaper machine system cleaners out there. Check the internet...... I thought that Blaser was sold on the premise that it contained "good bacteria" that ate the bad bacteria!
    It sounded like BS when the Blaser salesman came a calling. Surely all organisms like bacteria eat and crap in the coolant which causes the spoiling of the coolant.
    Buy Rocol coolant.....it does what it says on the box.
    Mar 2009
    1982
    boiling kills 99% of bacteria in the coolant.
    15362
    Quote Originally Posted by BRAIN-HURTS View Post
    Something very wrong with the above problem Blaser does not get bacteria I have had it in my tanks for 3 years and it is still as good as when it was first put in I would say that he has an oil problem and if he put in a good filter system to clean the coolant there would not be a problem
    The excess of tramp oil is what has caused the bacteria not the coolant, remove the oil and the coolant will be fine
    Mactec54
    15362
    Quote Originally Posted by Algirdas View Post
    Yes boiling water ( A+ ) and Dawn soap or Oil Eater and hot water works very good if not better than any type of flushing chemical's you can buy
    Mactec54
  1. M code for chip conveyor and flushing coolant?
    By J S Machine in forum Hyundai Kia
    Last Post: 07-21-2020, 01:18 PM
  2. Flushing out water of an air system
    By Keegan@jet in forum Uncategorised MetalWorking Machines
    Last Post: 11-18-2011, 08:10 AM
  3. Oil system flushing with Kerosene?
    By carbidecraters in forum Fadal
    Last Post: 03-03-2009, 04:06 AM
  4. Flushing/cleaning coolant reservoir?
    By speedofsound in forum Milltronics
    Last Post: 10-26-2006, 04:01 AM
