585,717 active members*
4,034 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > VF3 with video garbled problem
Results 1 to 8 of 8
    Dec 2009
    23
    This 1995 VF3 has a video problem (see pic below). We tried a new monitor and the same problem. We are thinking the video card is the problem. Anybody seen this particular problem? We were able to get it to work for about a week by nothing more than touching around the cables to sort of make sure they were seated good, but it's back to this. Also, I notice 2 types of video cards on ebay. It looks like you can get ones with floppy, and ones without. Can someone confirm they are interchangeable? I don't think we need the floppy. Except it will probably be nice if we ever have to reload parameters (by the way, how bad is reloading parameters, if it comes to that--just using the keyboard to enter them?).
    Attachment 456018
    Aug 2009
    1570
    Re: VF3 with video garbled problem
    ...we can hear you now. VF3
    comm check
    over
    Mar 2009
    1982
    Display itself is correct. Video module looks correct as well. Check the video memory. Are there any signs showing operating system status?
    Since the initial check of cables fixed it, look there again: connectors and line consistency.
    Dec 2009
    23
    Quote Originally Posted by Algirdas View Post
    How can you tell?
    How can you tell that?
    Visually? I did take stuff apart and inspected all the connections and found them to be solid. I think it is possible the problem is intermittent and it was just a coincidence that someone else was in there poking around right before it came up ok. But I can't be sure.
    You mean like jogging the axis to see if the control is actually up? I didn't try that. I'm not a HAAS guy. First time I've ever worked on one actually. I could explore that once I get back there. Could you suggest a quick way to do that?
    Quote Originally Posted by machinehop5 View Post
    comm check
    over
    Is that you Major Tom? --ground control.
    Mar 2009
    1982
    Quote Originally Posted by Micah View Post
    How can you tell?
    Raster is correct, frames are correct. Screen full of symbols. So there is path up to symbol generator. Part of screen contains "white noise" which is indication of video memory problem - addressing, refresh or hardware fault.
    Visually?
    Sure, no. Software tests - write read sequence. It's possible, that video memory is not readable by Operating System. Only the display reflects status of video memory in that case. For instance, the first and simpliest - write to video memory full zerroes. The display should be blank.
    risky, but yes. There are other signs of OS up: sounds, keyboard illumination, reaction to interlock switches, blinnking of some panel LED's . . .
    Jul 2014
    17
    It's the processor board.
    Dec 2009
    23
    Quote Originally Posted by cadmaker View Post
    You appear to be quite confident. Have you seen this condition before? It doesn't appear to be the video card. That was replaced today and the result did not change.
    Jul 2014
    17
    I've seen it several times when I was a haas tech years ago.
  1. Video Problem with New Hermes 810 NHI810
    By MrDos in forum Engraving Machines
    Last Post: 03-20-2012, 09:14 PM
  2. rotary table problem video
    By ceramdent in forum Linear and Rotary Motion
    Last Post: 12-14-2011, 09:43 PM
  3. Garbled Curves when saving SW2009 Drawings as DWG files
    By KevinWilkins in forum Solidworks
    Last Post: 04-13-2010, 05:06 PM
  4. Display Failure! Garbled/Repeating same line (VF2)
    By ralph@nes in forum Haas Mills
    Last Post: 11-26-2008, 04:28 PM
  5. Vista Video Problem
    By gblass1 in forum BobCad-Cam
    Last Post: 07-20-2007, 01:19 PM
