585,992 active members*
5,878 visitors online*
    Jan 2021
    Problem with X wall relief parameter
    Hi.
    This is my first post. I'm using a Mazak Quick turn Nexus 100 with Mazatrol 640T control.
    There's a problem with the X axis relief. When using BAR IN, the tool starts .02 smaller then the cutting point and has a relief of .01. Even if I change U4 parameter, it just adds it to the .01
    If I use a BAR OUT, it does the same thing
    It's like there's a basic .01 x relief plus what is added in the U4 parameter. It doesn't use to do that and I can't seem to find the source.
    Thanx for your help.
    Ian
    Nov 2020
    13
    Re: Problem with X wall relief parameter
    The program dimension is same as actual? If not, u need to calibrate the toolye with B61 ID and B63 OD
