585,969 active members*
4,452 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Setting parameter of hwacheon cnc lathe
    Hello everyone!
    I have 1 fanuc cnc lathe manufactured 30 years ago. The machine has no optional switch M01, the mechanic has set it to stop every tool change (similar to M01), so every tool change in a program has to press the start button one more time, Can you instruct me to reinstall parametes for the machine to run seamlessly.
    Thank you very much
    Jul 2019
    34
    Re: Setting parameter of hwacheon cnc lathe
    see PMC and setting again
    hello
    i have hwacheon sirius-u 2006
    the atc servo motor amplifire unit battery was died and shows u and 11 alarm code and in controller display (fanuc 18 m ) alarm code is 1440
    i lost machine manual
    please help me or send machine manual to solve this problem
    thanks.
  1. HWACHEON CNC LATHE SAMPLE PROGRAMS DUAL SPINDLE
    By Jcowles1986 in forum Turning
    Last Post: 09-25-2019, 06:55 PM
  2. Replies: 0
    Last Post: 08-10-2013, 02:31 PM
  3. Hwacheon lathe chatter?
    By the lathe guy in forum Uncategorised MetalWorking Machines
    Last Post: 04-28-2012, 02:16 PM
  4. Fanuc 18t weird tool offsets, Hwacheon lathe
    By mcshaner2k in forum Fanuc
    Last Post: 11-23-2011, 10:24 PM
