I’m looking for a canned cycle g code to rough in a groove on a lathe to feed back and forth in z when taking a new rough cut instead of g85 and only feeding from right (tailstock) to left (spindle), I can be more specific if needed, any help is greatly appreciated!
I want it to rough back and forth vs roughing 1 direction as I’m using a button insert with cutter comp set and p8
I program with igf and it doesn’t give me the option to change tool paths when roughing
This is programmed in igf rough mid od if that helps
Thanks again!
