585,589 active members*
3,208 visitors online*
IndustryArena Forum > CAD Software > Solidworks > Generate Geometry from Excel/CSV/TXT
    Jan 2021
    Question Generate Geometry from Excel/CSV/TXT
    Hi. My name is David I'm new here, thanks for having me.
    I have just started working at a new company and have been tasked with driving some improvements. They use Bysoft 7/Designer (solidworks). We do a lot of rectangular parts that have to be created then exported as DXF's.
    At the moment every rectangular part is drawn.
    My last company had SigmaNest software that had an excel import option. I could use an excel file with a list of dimension e.g below. From this information, it would generate the parts. Which was a massive time saver
    Part Name X dim Y Dim THK QTY
    Part 1 100 100 10 10
    Part 2 200 200 10 5
    Part 3 300 300 5 5
    Part 4 150 150 10 10
    Is there anything similar in Bysoft7/Solidworks
    Ideally would just convert this information direct to DXF. Or is there a program that can achieve this?
    Thanks in advance!
    David
    Jun 2015
    4154
    Re: Generate Geometry from Excel/CSV/TXT
    hy youtube ' solidworks excel driven part '
    Mar 2008
    683
    Solidworks has a tool that will automate creating drawings and exporting DXF files. You can set it up to run at night when you aren't using the computer.
