585,753 active members*
4,680 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Which drivers are best for nema 23 motors?
Results 1 to 6 of 6
    May 2006
    309
    Up to now I´ve been using Gecko G540 but I need to know if there are any better alternatives which will give a faster speed to my motors without loosing steps.
    Re: Which drivers are best for nema 23 motors?
    If you are trying to get the most speed, you need to increase voltage to the motors. Different drives won't make that much difference.
    Different motors can make much more difference than different drives.
    What are the specs of the motors you have, and what voltage power supply are you using?
    May 2006
    309
    The steppers are KL23H276-30-8B and the power supply is marked S350-48 7.3A I measured the output voltage to 44V.
    Do you have them wired bipolar parallel?
    You probably wouldn't see much difference going to a drive that can supply the rated 4.2a, unless you also increase the voltage to around 70V. And at that point, I'd find a motor with more torque as well.
    May 2006
    309
    OK.
    Do you think that mine stepper mototrs are to small for a Taig mill? Which motors would you recommend?
    No, they should be fine for a Taig.
  1. Replies: 5
    Last Post: 08-03-2017, 11:28 AM
  2. XHC Mach3 4-axis control card with M542t drivers and Nema 24 stepper motors
    By usajet in forum CNC Machine Related Electronics
    Last Post: 12-04-2016, 03:02 AM
  3. Replies: 0
    Last Post: 12-04-2016, 03:00 AM
  4. Replies: 0
    Last Post: 12-04-2016, 02:51 AM
  5. Nema 34 Stepper Motors/Drivers - induction ratings
    By BrianJenkins in forum Stepper Motors / Drives
    Last Post: 01-14-2015, 05:48 AM
