The best thing you can do to that machine is to convert it to run Mach 3 with g540 motor controller. I ran a stock techno for years with the standard g code interface. It was horrible. I then stepped up to running it with the standard electronics and a controller called Gallad with the Kay interface. Finally I bit the bullet and converted it to run mach3. I now get full use of the machine with incredible speed, power and features like spindle speed control and a Z touch off plate.
In retrospect, I should have done it years ago!
http://www.glenspeymillworks.com Techno LC4896 - 2.2Kw Water Cooled Spindle | Moving Table Mill from Omis 3 CMM, 500Lb granite base | Epilog Legend 32 Laser Engraver
