585,728 active members*
4,120 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Problem with Nema 34, DM860, DB25-1205 and Mach 3
    Dec 2020
    Hi guys,
    I tried it with the search function, but I can't find a solution to my problem.
    I bought a set from ebay, Nema 34 878oz 2A 8 wire step motor, DM860 driver, power adapter and a DB25-1205f breakout board. There was no manual and I couldn't find the correct wiring. EVERY shown wiring on YouTube looks completly different. I tried many of them, but none responses to Mach3. Maybe it's a wrong config in Mach3, maybe a wrong wiring. Is there an idiot proof step by step solution on the web? I couldn't find the right one...
    I'm fighting since days with this problem!
    Kind regards and thanks in advance
    Me109K4
    Edit: The motors are wired correctly to the driver, the problem is the wiring from the BOB to the driver and the Mach3 settings
    Dec 2012
    199
    Re: Problem with Nema 34, DM860, DB25-1205 and Mach 3
    Here you will find a manual for the BOB https://www.steppermotorcanada.ca/db25-1205f.pdf
    Don't forget to connect the + 5 V, if possible two separated +5V supplies
  1. Db25 1205 bob
    By brontoo26 in forum DeskCNC Controller Board
    Last Post: 09-08-2018, 08:03 AM
  2. Db25-1205
    By davidmccormick6 in forum DIY CNC Router Table Machines
    Last Post: 01-20-2018, 05:40 AM
  3. Possible problem with BOB db25-1205
    By Lc1975 in forum Stepper Motors / Drives
    Last Post: 06-12-2016, 08:22 PM
  4. db25-1205 controller question
    By wmpinion in forum CNC Machine Related Electronics
    Last Post: 04-24-2015, 02:25 AM
