Hello,
Does anyone know the parameter corresponding to the Single Step option?
I would like to add a button to activate or deactivate it directly on the button bar.
Best regards
Hello,
Best regards
Hello,
I have found, the parameter is _hw_single_step. I'll share it with you.
Here is the command to pass in the BtnTop.txt bar:
cmd: "Machine.Override.Single_Step" "" image = "Icons / IMG_Singlestep.png" imagechange = "True" stroke = 1 color = # 0ffca0 updown = "_ hw_single_step == 1" updatefast = "true" tooltip = "Block to Block"
You will find attached the corresponding image and the result. The black contrasts little with the gray background, I will change the image to white.
Best regards
