585,715 active members*
3,846 visitors online*
    Dec 2014
    AFTER THE TOOLCHANGE THE SPINDLE STOPS
    HELLO EVERYONE
    SUDENLY WHILE EVRYTHING WAS WORKING NORMAL THE MACHINE (MAZAK VTC-300C-II) STOPS AND WAIT WITHOUT SPINDLE AFTER THE TOOLCHANGE.THERE IS NOTHING WRONG WITH THE PROGRAMME.IF I PRESS THE RESET BUTTON AND THEN RUN THE PROGRAMME AGAIN IT DOESN'T WORK BUT IF I PRESS THE EMERGENCY STOP BUTTON AND THEN RYN THE PROGRAMME IT WILL WORK JUST UNTIL IT GETS THE OTHER TOOL AND STOP AGAIN.
    THANKS FOR THE HEPLING ANYWAY
    Dec 2014
    Re: AFTER THE TOOLCHANGE THE SPINDLE STOPS
    good day,friends
    I am facing a problem on mazatrol fusion 640M.
    I start a programm with 1 tool (for example 5).When tool 5 is on spindle ,the programm is executing,properly.After tool cahnge(for example no7) the spindle stays standby,with no error,nothing!
    if I split the 2 programms each of tool load by hand on spindle,both programms running with no problem.
    can you please help?
    Nov 2020
    13
    Do u have ATC STOP menu ON?
    Before T001T0M6, Add M5, and M19, at seperate blocks.
    Btw, when it stops, does the cycle start button is ON?
    Dec 2014
    Hi yes the cycle start button is on
    Feb 2021
    10
    Take the program and delete it from memory. Rewrite and reload through data io . Do you have something funky in the tool data? Does this machine have a probe? Make sure it is not sending faulty signals . I have seen this plenty on 640 and matrix , I can not explain it but erasing , rewriting , uploading again seems to solve the issue.
