585,676 active members*
4,189 visitors online*
IndustryArena Forum > CAD Software > Autodesk > AutoCAD - Need Extrude via Loft
    Jan 2021
    5
    Hello;
    I am needing to extrude an inner and outer ellipse so as to subtract the inner extruded ellipse later, BUT what I really want to do is Loft the inner and outer ellipses so they taper to the other end which are circles. I can loft both ellipses, but when trying to subtract, it seems that shell was only extruded during loft, not like when doing a regular extrude, so subtracting doesn't work.
    Any ideas ?
    Re: AutoCAD - Need Extrude via Loft
    LOFT has an option for solid or surface.
    1216
    I'm very rusty with Autocad and haven't used the most recent versions,so I might be wide of the mark here.Don't they use some weird term for extrude?Would it be feasible to create the outer and inner objects on different layers and then do a Boolean subtraction of the inner?
    Jul 2011
    400
    I have not used in autocad in a long time. The command you might want is called draft. It puts a slope on things.
  1. Loft in XR8
    By sudsy in forum OneCNC
    Last Post: 12-29-2020, 08:18 PM
  2. Why can't I loft cut?
    By Analias in forum Uncategorised CAD Discussion
    Last Post: 11-27-2012, 10:36 AM
  3. Can anyone help me use the loft boss...
    By cloverfield333 in forum Solidworks
    Last Post: 07-24-2009, 11:14 PM
  4. my college loft
    By zachjowi in forum WoodWorking Topics
    Last Post: 01-21-2008, 04:38 AM
  5. modifying a loft
    By PTcutter in forum Solidworks
    Last Post: 06-18-2005, 01:22 AM
