585,741 active members*
5,084 visitors online*
    Jan 2021
    RS-232 cable for M2521 Milticam 3000
    Hi, in our M2521 TCP port failed. I have to use Com-port RS-232.
    I have drawn up a connection scheme and manufactured the cable.
    But Multicam 3000 does not connect to PC.
    ?an you give a scheme of the cable and settings RS-232 for PC?
    Sep 2006
    118
    Re: RS-232 cable for M2521 Milticam 3000
    Not sure about the MC 3000 but the older MC's that used a Serial cable for connection to the computer, and used WinDNC (Win98) or MX32 to transfer files. If i'm not mistaken a DB-9 Null Modem cable is needed..
    Jan 2021
    The problem is solved. I added CTS wire in the cable to the eight pin. I used 'Motion Connection' and 'Job Server' programs.
    Feb 2022
    Quote Originally Posted by Andy_kap View Post
    Is it work fine with it now via RS232 and without ethernet?
    Please could you share that soft to try. Unfortunally we have the same situation...
  1. Need computer cable for Gerber dimension 200 or pinout diagram for cable.
    By Mattster1 in forum Commercial CNC Wood Routers
    Last Post: 09-06-2019, 07:49 AM
  2. Need pinout for Prolight 3000 lathe turret cable
    By DSpeck in forum Benchtop Machines
    Last Post: 05-14-2019, 02:37 AM
  3. Replies: 0
    Last Post: 01-22-2010, 07:06 PM
