585,930 active members*
3,665 visitors online*
    Oct 2019
    P232 No program no
    Good morning when I want to make a tool change, I get this alarm, the machine I just bought has a Meldas M3 controller, someone who can help me
    Feb 2012
    9
    Re: P232 No program no
    Did you find a solution? I have a similar issue
    Sent from my SM-N985F using Tapatalk
    Jan 2022
    Day late and a dollar short. Had this problem as well. Macro call was for a program number and should instead be set to 0. This calls the internal M6 command. I thinks it's either 7003 or 7103. Check for it.
    Nov 2012
    363
    Quote Originally Posted by Buzzman3706 View Post
    Full disclosure: Not an expert!
    Tool change operations come in different flavors. I know that on my particular machine (Dyna DM4400m using an M3 control), the tool changer is actually has its own independent sub-system, including its own CPU. The interface between the M3 and that subsystem is via a TC program (in this case, 9000). If you don't have the program in there, the TC will *never* work. On other machines (also from Dyna) there is no separate sub-system. I haven't had the opportunity to look at these machines in person, but my sense is that the TC is built into the PLC. The point to all this is that I am wondering if you are missing a TC program. This would not be uncommon for a machine that has been sitting for a long time so the battery died; that would corrupt/erase the memory....
    Note: I'm using the term macro and program as kind of the same thing, which is probably incorrect.
  1. program of tab program in mori sv 400 and program tool chance
    By hmtam1311 in forum Mori Seiki Mills
    Last Post: 12-10-2017, 02:54 PM
  2. Replies: 1
    Last Post: 02-11-2015, 02:38 AM
  3. P232 No Program No. (error)
    By koonta in forum OKK
    Last Post: 04-30-2013, 07:44 PM
  4. Replies: 4
    Last Post: 03-06-2013, 07:56 PM
  5. Replies: 0
    Last Post: 12-27-2010, 09:55 AM
