585,982 active members*
4,736 visitors online*
IndustryArena Forum > CAM Software > EdgeCam > Edit Edgecam Dimensions linear dim display Precision
    Jan 2021
    Hi everyone
    I new to edgecam, and i have a problem, i import file model from inventor autodesk to edgecam, the dimension from inventor is 24.375, but dimension in edgecam showing was 24.38, can some one help me fix this problem, thankyou!
    Sep 2011
    9
    Re: Edit Edgecam Dimensions linear dim display Precision
    try this. click on file tab, preferences, under the general tab, tolerance ,change system to .0001 and display to .0001. this might help.
    Greg
    Sep 2011
    9
    to change the number of decimal to display when dimension do this
    1) under the setup tab, click on dimension (not the little arrow pointing down but the word dimension.)
    2) dimension style box pops up. click on tolerance tab
    3) change decimal places to 4
  1. Making Pro-E display more accurate dimensions
    By nateman_doo in forum PTC Pro/Manufacture
    Last Post: 02-14-2014, 04:20 PM
  2. Edit display Render, Wireframe not working
    By cncorbust in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-28-2009, 02:20 PM
  3. Torchmate CAD node edit precision?
    By MoparJon in forum Torchmate
    Last Post: 12-23-2008, 09:39 PM
  4. how to edit edgecam post processor
    By ineedhelp in forum EdgeCam
    Last Post: 06-26-2008, 07:41 PM
  5. gas pipe & linear bearing dimensions relationship
    By zoltan in forum Linear and Rotary Motion
    Last Post: 06-13-2005, 09:12 PM
