Originally Posted by
bertus.nl
hi
"And been wanting to clamp parts from ID, from inside, so there's a key, and i turn it,
And then there's a message:
" 2090 chucking confirmation switch alarm ",
And the machine wouldnt work. What is it,
And what can i do about it?"
Only right awnser is adjust the chucks so you're chuck is in the right position and not at the end of it's reach
there are two little stripes on the body of the chuck at te nr 1 position. open or closed the 3th stripe must be in between, to clamp
at the max .
moving proximetie switches is not the best solution if you do not kwow what youre doing.
greeting bertus
