585,992 active members*
5,672 visitors online*
    Jan 2021
    11
    Z-axis not moving
    Hello members,
    I need your help. My Z-axis is not moving. What could be the problem?
    I really need assistance because I have alot of projects on hold because of this problem.
    Thank you very much
    Apr 2004
    5737
    Re: Z-axis not moving
    It might not be hooked up right, you could have bad pin assignments, a bad wire, a fault in your breakout board, a blown fuse, a computer issue, or a mechanical problem, among other things. Did it ever work, or is this the first time you've tried to use it?
    Andrew Werby
    Website
    Dec 2005
    594
    Controller? Steppers or servos? Drives? Nowhere near enough information to troubleshoot.
  1. axis not moving Only DRO moving on mach3 screen for cnc router 6040
    By bingaom in forum Charter Oak Automation Support Forum
    Last Post: 09-09-2014, 08:54 AM
  2. Replies: 12
    Last Post: 02-07-2014, 02:40 PM
  3. Z AXIS - Moving bearings or moving rails ?
    By TrickyCNC in forum DIY CNC Router Table Machines
    Last Post: 02-28-2012, 06:22 AM
  4. a problem with slaved A-axis moving properly relative to Y-axis
    By zool in forum Mach Software (ArtSoft software)
    Last Post: 07-06-2011, 03:45 AM
  5. Z DRO moving, axis not moving
    By JC50 in forum DIY CNC Router Table Machines
    Last Post: 03-13-2011, 02:49 AM
