585,931 active members*
5,421 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Dynapath > Dynapath Delta 20 tuning with a scope ?
Results 1 to 14 of 14
    I have a JM325 mill with a delta 20 control.
    I have all the associated manuals for the drives, controls, etc including full schematics.
    Having trouble getting my Y axis servo lag to spec.
    I have an oscilloscope with memory function that I could use to see exactly whats going on but I'm note sure where to connect the leads to obtain the signal.
    The scope is powered by an isolation transformer so no risk of a ground occurring.
    Thanks in advance
    Aug 2009
    1573
    Re: Dynapath Delta 20 tuning with a scope ?
    ...Mode Select> (5)Setup> TM4 Lag Display was available... I think on D20's.
    Quote Originally Posted by machinehop5 View Post
    Yes...I know how to display the lag...I want to watch the Y motor voltage trace on the scope so I can see exactly where the issue is.
    The one of my documents shows sample graphs and outlines exactly how to correct problems to obtain the "normal" graph....
    Aug 2011
    121
    Nitrochuck,
    Are these Servo Dynamics drives? If so, there should be a small header with short pins next to the pots. What you typically want to watch is the tachometer output, that is normally what the response graphs show in the manual and this will tell you what the motor shaft is doing. Your manual should specify the tachometer pin, in my case it is TP6 on my Delta 60M. Connect your scope to the tach pin and observe the response to a step input to the drive.
    RT
    Quote Originally Posted by cngbrick View Post
    Nitrochuck,
    RT
    Yes Rt...
    SD1525-10.... great...I believe my tach pin is the same...ill attach the probe there and see if I can get it better tuned....
    Besides the lag reading being higher than suggested the motor growels when using the rotary know on the pendant to jog and occasionally stops out of position during a program causing it to stop...no alarm or trip but sits waiting for the IP signal
    Aug 2011
    121
    Nitrochuck,
    You will need to supply a step input to the drive signal input to calibrate the drive, are you set up to do this?
    You should also check the brushes on the motor and possibly the tachometer if you haven't done so.
    RT
    Nitrochuck,
    RT
    Can I use the rotary pendent on the machine set to the .0001 scale to provide the input signal ??
    Aug 2011
    121
    You'd have to put a scope on the drive signal input to see if this is produces an actual step input and if it's loon enough for the motor to reach steady state speed.
    In my case I disconnected the drive signal coming from the controller and used a 9V battery. Start by putting a 1 to 5 kOhm resistor between the signal input (pin 2 in my case) and signal common (pin 4) so that the control has a zero movement command. Confirm that there is no motor movement, if there is then adjust the balance pot to stop the motor. You can now apply connect the 9V battery momentarily (do not clip the battery in or better yet, use a switch) to the signal input and signal common pins to generate the step input. Be careful, the motor will accelerate at maximum rate in a direction dependent on the polarity of the battery so make sure the machine is in a position to move in either direction. Remove the battery to stop the motion, switch the battery polarity to switch the motor direction.
    Again: make sure the axis you are calibrating can safely move in either direction at full velocity before applying the battery! If you are unsure about this have someone stand ready to push the e-stop in case things get out of control.
    Does this help?
    RT
    Does this help?
    RT
    Ok...so for the graph to have similar structure to the examples in the manual with all the rise and fall features it needs a distinct momentary pulse to get the motor up to full speed with no conflicting fluctuations in input signal....
    So full speed is not going to be limited to the software's 300 IPM restriction its going to be dependent on the servo cards output voltage and the
    time at voltage...probably dangerous fast
    Aug 2011
    121
    Nitrochuck,
    Your question prompted me to have a look at my manual as it's been about 8 years since I had to tune a servo on the mill.
    The manual states "Apply a small step input command signal and watch the tach output as observed on an oscilloscope on TP6. Observe the tach output as the motor stops." It sounds like you should be able to do this test with a smaller voltage if you are concerned about attaining a high speed. In that case you can substitute a 1.5 V AA cell and see what happens. I'd still recommend you take the same precautions about positioning the axis so that it can go either way without danger and prepare to hit e-stop if necessary.
    RT
    Great..ill start with the lower voltage on a pushbutton....
    I may get some electrical cleaner first and trying cleaning the motor in place...I've read the Y motor is in the path of coolant dripping quite often and suffers from it....
    I was told by a knowledgeable tech that the tach wires are very very fine and it's not advisable to try and service it myself.
    Hopefully cleaning and tuning will get me where I need to be...thanks
    Oct 2017
    27
    Jun 2021
    II looked at your animation. And to be honest, I've watched it many times. What you're doing is beautiful.
    Jun 2021
    I looked at your animation. And to be honest, I've watched it many times. What you're doing is beautiful. I wonder how long you've been studying this? Or are there special courses for this purpose? I remember drawing weapons as a kid, but I can't go to a graphic designer to translate them into a video. I want to learn this https://ballachy.com/best-ak-47-scopes-optics/ In general, I love war games very much. I focus more on drawing weapons and everything around them. For me, this is much more important than the plot of the game. I love the game crisis.
  1. Dynapath Delta Tuning
    By DNS1 in forum Tree
    Last Post: 04-14-2024, 12:36 AM
  2. Servo tuning without an O-scope
    By southernexplore in forum Gecko Drives
    Last Post: 02-01-2017, 01:15 PM
  3. O-Scope Tuning Noise
    By RakmUp in forum Gecko Drives
    Last Post: 07-13-2016, 09:43 PM
  4. Tuning with and old-school O-Scope
    By MattTheNoob in forum Gecko Drives
    Last Post: 04-19-2014, 07:48 AM
  5. G 320 tuning w/scope
    By Cruiser in forum Gecko Drives
    Last Post: 09-08-2006, 04:18 AM
