585,759 active members*
4,004 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Wiring 240v german spindle to ameriacn welding plug.
Results 1 to 6 of 6
    Feb 2020
    I'm trying to wire up this german AMB FMU-DI spindle to my diy cnc router.
    It came with a two-prong euro plug.
    The manufactuer says it will run fine on 240v 60hz which is what I have in my shop for the welders.
    So I bought a nema 6-50p plug to connect the spindle to the welder outlet.
    I was tghinking I would just connect the two leads of the motor to the nema 6-50 plug, but now I am wondering if this will cause issues and am scared to ruin my new $750 spindle.
    Can anyone shed some light on this?
    T
    Dec 2013
    5717
    Re: Wiring 240v german spindle to ameriacn welding plug.
    That will work fine.
    Jim Dawson
    Sandy, Oregon, USA
    Apr 2004
    5735
    That might be a higher-amperage circuit than the tool is expecting, It will still work, but if it overheats you shouldn't expect the circuit breaker to save it. You might also want to run it off a relay box, so you can turn it on and off with software commands (M3/M5).
    Andrew Werby
    Website
    Feb 2020
    Quote Originally Posted by awerby View Post
    Could I run an inline blade fuse or something to protect it?
    T
    Apr 2004
    5735
    I don't see why not.
    Andrew Werby
    Website
    15362
    Quote Originally Posted by gret83 View Post
    T
    Check to see if there is a Ground wire in the cable unless the spindle is rated Double insulated then you need to add cable with a Ground wire
    Other than checking for the Double insulated square you would be good to go and add a 2 fuses for your 240v single phase supply as your welder plug will have a much higher amp rating than what your spindle needs
    Mactec54
  1. EZ-path 1 wiring for 240v 460v presently
    By prostockstan in forum Bridgeport / Hardinge Mills
    Last Post: 09-05-2023, 01:39 PM
  2. Replies: 58
    Last Post: 11-10-2017, 02:17 AM
  3. Replies: 2
    Last Post: 08-20-2010, 06:41 AM
  4. Wiring Slo-Syn 240V 1 Phase Motors
    By PerPlexed in forum Servo Motors / Drives
    Last Post: 06-17-2009, 04:24 AM
