585,605 active members*
3,246 visitors online*
IndustryArena Forum > CAM Software > Vectric > Vectric options
    Jan 2021
    Vectric options
    I'm looking for information on whether or not anyone has found success with using an alternative program to trace bitmaps as nicely as vectrics software elsewhere? I am running b solid, on the Biesse Rover S 1536,
    I work in a furniture store and looking into the possibility of doing some sign work, I used vectric exclusively for years and found that it has the best bitmap trace feature around which comes in very handy when doing sign work or logo work,
    has anyone found a better program to make dxf files. For design purposes Vetric works great, Biesse advised it will not work with our machine for toolpaths.
    Re: Vectric options
    I would think that you could create a Vectric post processor to use it with your Biesse.
    1213
    Re: Vectric options
    Given both the number of Biesse machines and the number of Vectric users surely the two companies ought to be talking to each other in order get some mutual benefit.Has the OP tried to use Inkscape for tracing bitmaps?I find it hard to use,but it does a job once you have some familiarity.
    Re: Vectric options
    Aspire comes with at least 10 Biesse post processors. Vectric should be able to create one for his machine.
    I wouldn't believe what Biesse or any of the other major manufacturers tell you. From my 25+ years of experience with these companies, I don't have a lot of trust in what they tell me.
    Jan 2021
    Re: Vectric options
    I have used inkscape I just do not find it to work as well as vectric, but yeah it works.
  1. Vectric's new Cut2D
    By Greolt in forum Cut2D / Cut3D
    Last Post: 01-05-2022, 02:43 PM
  2. Vectric
    By Dukie94 in forum Aspire
    Last Post: 11-05-2015, 06:08 AM
  3. Vectric 2d
    By mike2768 in forum Vectric
    Last Post: 11-21-2012, 01:36 AM
  4. Which Vectric Products do I need?
    By ntww in forum Vectric
    Last Post: 06-25-2011, 11:25 PM
  5. WTB Vectric
    By tdnp in forum Vectric
    Last Post: 03-22-2009, 04:43 PM
