585,975 active members*
4,466 visitors online*
    Dec 2003
    189
    strange motion when referencing axis
    After a re-build of my 3 axis mill (Mach 3, USB Smoothstepper) I'm having a weird problem when referencing each axis to it's homing switch.
    I'm in the Diagnostics screen and when I hit the reference x button is slowly creeps to the sensor and stops as it should upon contact.
    Next, I refence Y. Not only is the Y axis moving but now the X starts drifting away from it's home sensor as well simultaneously.
    I've never had these kinds of problems in the past.
    All three axis work fine commanded from the keyboard or pendant.
    Any ideas?
    Is a sentance fragment?
    15362
    Re: strange motion when referencing axis
    Quote Originally Posted by Tristar500 View Post
    Any ideas?
    You have EMI noise in your system check Grounding and shield Grounding USB cables can be a problem also if the are not shielded
    Mactec54
    Dec 2003
    189
    I've completely rebuild and rewired the control box and removed all AC voltage from inside the box. Only thing in this steel box is 3 gecko 201 drives, Smooth Stepper V 1.2 , Smooth stepper breakout boardC25 V 2.1, 12 VDC relay board for the proxy sensors.
    Running the machine with pendant removed, Z tool setter removed, and the spindle completely unplugged. Replaced power supply. Still having the same problems.
    This machine used to run on Mach 2/Win 2000 and had no issues.
    I'm still having issues with uncommanded movement from bot the x and y axis when referencing home in the diagnostic screen or on the main screen when hitting the "reference all home" button.
    I don't think this is an issue with noise anymore.
    Any ideas?
    35538
    Contact Warp 9 and ask them. The Smoothstepper handles the homing.
  1. Having Problems when Z axis is referencing home
    By 72volvo145 in forum Sharp CNC
    Last Post: 08-21-2015, 04:27 AM
  2. Referencing axis at 0.0
    By Mike 1948 in forum Mach Software (ArtSoft software)
    Last Post: 01-09-2015, 06:21 PM
  3. J325 axis referencing
    By MadPickinSkills in forum Tree
    Last Post: 01-23-2011, 03:02 AM
  4. Deckel FP4 NC 4th axis not referencing HELP!!
    By vsengineering in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 08-04-2010, 04:21 AM
  5. Referencing of C-axis
    By lolo26 in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 08-25-2008, 08:55 PM
