584,863 active members*
4,854 visitors online*
Results 1 to 12 of 12
    Dec 2016
    14
    MB2 ESS relay connection
    Hi guys,
    I am trying to connect a 24Vrelay to the MB2, to operate a pump on spindle start. I have configured the output y302 as a 2nd output for the spindle forward output, and the light follows the on/off as expected.
    Problem is i have connected the coil of the relay to Y302 and 24V on the BOB, but the coil stays energised no matter what the status of the output is... Am i doing something wrong?
    Thanks in advance
    Tim
    Nov 2012
    1267
    Re: MB2 ESS relay connection
    Did you remember to add the flyback diode to the relay coil? If not, you may have fried the optocoupler.
    Dec 2016
    14
    Quote Originally Posted by CitizenOfDreams View Post
    Dr forgive my ignorance but not sure how or what is needed for a flyback diode.. so no, I didn't add one.
    Could you explain a little please?
    Nov 2012
    1267
    A relay coil is an inductive load. When you switch off an inductive load, there is a large voltage spike that can (and does) destroy sensitive electronic elements such as transistors.
    Whenever you control a relay with a transistor (or an optocoupler, which contains a transistor), you must shunt the relay coil with a diode. The diode dissipates the back EMF and prevents the voltage from spiking to dangerous levels.
    The MB2 manual mentions the diode on page 14: http://www.cncroom.com/downloads/MB2...al%20E16R5.pdf
    24216
    If you need a suggested part, 1N4007 is the popular one.
    Al.
    Albert E.
    Jan 2007
    626
    Thought about using one of the relay contacts on your VFD instead?
    Nov 2012
    1267
    Quote Originally Posted by Sterob View Post
    That is a good idea. (Most) VFDs have one or two relays that can be programmed for different functions, such as "Alarm", "Spindle rotating", "Spindle at speed" and so on.
    Depending on the current rating of the pump, you may connect the pump directly to the VFD, or use an external relay.
    24216
    It is always advisable to use an external relay or operator, if you overload and damage the internal relay, it is costlier to fix!
    Al.
    Albert E.
    Dec 2016
    14
    Al.
    Thanks Al
    I have a curious situation going on..;l
    I bought one of these
    https://www.amazon.co.uk/gp/product/...?ie=UTF8&psc=1
    After the advice yesterday - i think it should be ok for the task.... i have set the y305 output to come on when i activate the spindle (for the pump) and though i see the output light on/off when commanded, the relay state does not change...
    For learning and incase i wanted extra i also purchased this
    If i wire this up it is the same behavior... and i was curious though the 'input side' only has to COM terminals, and its says pnp/npn input, am i right in thinking that 24V to the COM?
    Whichever is correct i can not get any change of signal lights on the relay or optocoupler board even though the MB2 light is active on/off....
    24216
    IIRC, the MB2 states a sinking opto output, if using it with a external relay board that has opto input, the recieving opto has to be set to sourcing input.
    Al.
    Attached Files Attached Files
    Albert E.
    Dec 2016
    14
    Al.
    So the relay board is opto isolated inputs with a high/low jumper. Am I correct in saying the high would be sourcing?
    24216
    I would read it that way, see if it works, it should not cause any problems either way, just only one way will work.
    Al.
    Albert E.
  1. Arcing connection on Laser CO2 tube connection
    By pcaulfie in forum Laser CO2 Tubes, Diodes, RF and Power Supplies
    Last Post: 11-06-2015, 07:00 PM
  2. 48V Relay
    By tulsaturbo in forum CNC Machine Related Electronics
    Last Post: 03-16-2011, 11:54 PM
  3. 24Vdc Solid State Relay not the same as mechanical relay??
    By cjchands in forum CNC Machine Related Electronics
    Last Post: 11-10-2010, 07:40 AM
  4. Using a solid state relay as a main stop relay
    By garagefela in forum CNC Machine Related Electronics
    Last Post: 02-26-2010, 11:27 PM
  5. RPC with a relay
    By Shanghyd in forum Phase Converters
    Last Post: 06-30-2009, 12:02 PM
