Hi I'm using cambam to get gcode for lettering and my machine is cutting it in reverse
One of your axis is probably backwards.
ger21 is probably correct, check the movement of your X and Y axis.
The cutter should move in the material as follows:
+Y
o --------------> +X
John
that did it thanks guys
