585,997 active members*
5,010 visitors online*
Thread: F360 & GRBL
    Feb 2020
    4
    F360 & GRBL
    Hi, I'm just getting my feet wet with Fusion 360 and GRBL as I build my CNC plasma table.
    I drew up a simple shape and did the CAM work in Fusion360. I picked the stock plasma cutter in Fusion360 and the simulation worked fine.
    When I went to post process the CAM into the GRBL post processor, I got an error saying "The CNC doesn't support the required tool/process. Only laser cutting is supported"
    I switched the tool to the laser cutter, re-checked everything and t seemed fine but still wouldn't post process.
    I checked the autodesk CAM updates and it's the most current version of GRBL.
    I'm a bit stumped about what's wrong.
    I hope that I can get a bit of guidance here...
    (if I'm in the wrong sub-forum my apologies)
    Mar 2015
    409
    Re: F360 & GRBL
    I think you should post your question in a fusion 360 related (sub) forum.
    https://www.cnczone.com/forums/autodesk-cam/
    Feb 2020
    4
    Re: F360 & GRBL
    Thanks @hfjbuis. I wasn't sure if it was a F360 problem or a GRBL problem.
  1. F360 Haning up this morning
    By smokediver576 in forum Autodesk CAM
    Last Post: 03-15-2017, 03:36 PM
  2. F360 wants to mill my vise.
    By jttoner in forum Autodesk CAM
    Last Post: 01-20-2017, 12:10 AM
  3. Replies: 1
    Last Post: 08-19-2016, 11:57 AM
  4. Change Dimension in F360
    Last Post: 08-14-2016, 07:30 PM
  5. Need graphics card for f360
    By Cferrell84 in forum Computers / Desktops / Networking
    Last Post: 07-20-2016, 05:05 AM
