585,981 active members*
4,037 visitors online*
    Nov 2015
    260
    Question about transformation
    Hello. I have questions about the "Transformation" function. What is it for. What can you do with it and how do you use it.
    Why is the value 1 set in the settings e.g. A1 B2 and C3 and the rest to 0
    Mar 2017
    1311
    Re: Question about transformation
    Transformation feature is basically coordinate system affine transformation.
    https://en.wikipedia.org/wiki/Affine_transformation
    It is threated as special "offset". Therefore only present in working coordinates.
    It can be used to shift/scale/rotate toolpath, to position workpiece or to compensate for machine inaccuracy.
    PCB tutorial is great example.
    Nov 2015
    260
    Thanks for the information. I've already thought of that. I was just confused about the values that were entered there, because I have no knowledge of the matter.
    Mar 2017
    1311
    Those values are elements of transformation matrix. I had to name them somehow.
  1. coordinate transformation matrix
    By karangetang in forum PlanetCNC
    Last Post: 01-28-2019, 04:45 PM
  2. Post processor transformation
    By korakian in forum Mechanical Calculations/Engineering Design
    Last Post: 12-02-2011, 09:00 AM
  3. Machining with part transformation
    By topsolidrapid in forum Uncategorised CAM Discussion
    Last Post: 05-12-2009, 03:34 PM
  4. Transformation -> Mirror
    By lamed in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 06-26-2008, 11:50 AM
