585,970 active members*
4,130 visitors online*
    Jan 2021
    CNC 3018 Pro Z Probe pin
    I have bought cnc 3018 Pro machine and I would like to install in it z probe, but I don't know which pin is responsible for that? Is it even possible in my model? Bellow images for my motherboard:
    May 2004
    210
    Re: CNC 3018 Pro Z Probe pin
    On an Arduino Uno, the GRBL Probe input is on A5. I suspect this board follows the Uno pinout which makes it pin 28 on the processor on your board. Unfortunately it doesn't seem to have a probe pin connector. So much for "Pro". You could try using a DMM to find if pin 28 goes anywhere.
    By the way, the standard woodpecker board (which does follow the Uno pinout) has an unlabeled pin that is the probe input. Are you sure the board pictured is the board you have?
    Also, what are the "Steering Gear" pins for?
    Jan 2021
    Most definitely this is my board (attached real photo). Thank you it seems that pin 28 is connected to right pin of what is labelled on the image as "Knife". It is also written on motherboard as J-A5 so I believe it is it. I have no idea what is "Steering Gear" in my machine they are unused.
    Aug 2004
    50
    I have the same. Did this work for you?
    Mike N
    No good deed goes unpunished.
  1. CNC 3018 Pro Problem With Z-Probe/Heightmap
    By JackJTR in forum Arduino
    Last Post: 12-30-2020, 12:06 AM
  2. Replies: 15
    Last Post: 02-26-2018, 03:00 AM
  3. TP-100 Probe - Compare Performance Motion probe to IMService probe
    By dgoddard in forum Digitizing and Laser Digitizing
    Last Post: 04-06-2013, 07:13 PM
