585,748 active members*
3,523 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > MACH3 CNC driver optocoupler isolation 5-axis stepper
    Feb 2021
    Hi.
    I would like to know that another type of software is compatible with this CNC driver apart from match3 and EMC2, well basically I want to know if it can be used in another operating system apart from windows and linux.
    thanks
    link driver cnc:
    https://www.amazon.com/Engraving-Mac.../dp/B082DSWSLY
    Attached Thumbnails Attached Thumbnails Interfaz-de-placa-de-conexión-CNC-de-5-eje-sinlog1.jpg
    Nov 2012
    1267
    Re: MACH3 CNC driver optocoupler isolation 5-axis stepper
    This is nothing more than a parallel port breakout board. It does not interact with the operating system or the software in any way. It just buffers and isolates the signals going to/from the parallel port.
    In other words, it will work with any CNC software that uses the parallel port. (So, basically, either Mach3 or LinuxCNC.)
