Frequently I will make a drawing in VCP using circles an squares and combine them, cutting only the parts I don’t need.
I set the cut to be outside and when previewed some of the cuts are inside and some outside.
And when I select “ join vectors “ it can say 5 open vectors but the “join” command is grayed out.
How can I correct this.
In the past I have just given up and went outside of VCP and drew it then import it. I would really like to use VCP TO MSKE THE DRAWINGS WITH.
THANKS
