585,982 active members*
4,806 visitors online*
    Sep 2003
    1469
    Vcarvepro drawing problem
    Frequently I will make a drawing in VCP using circles an squares and combine them, cutting only the parts I don’t need.
    I set the cut to be outside and when previewed some of the cuts are inside and some outside.
    And when I select “ join vectors “ it can say 5 open vectors but the “join” command is grayed out.
    How can I correct this.
    In the past I have just given up and went outside of VCP and drew it then import it. I would really like to use VCP TO MSKE THE DRAWINGS WITH.
    THANKS
    1225
    Re: Vcarvepro drawing problem
    Are you using the Vector Validator option to locate the problem areas?If they won't join its probably an indication that the entities are located in such a way that you are asking them to do the impossible.I can't remember if there is a tangent snap option in Vcarve.If not you may need to draw the straight lines in their desired location and then use the fillet option to create the radii as this ensures the entities are in contact and I believe it also joins all three entities (the two lines and the radius).If you try to cut an outline that isn't joined,the machine is likely to behave in the manner you describe as it may default to left or right of the vector and will define that side from the order of creating the endpoints.
    Apr 2005
    304
    Can you share the drawing, after cutting extra parts?
    Make no mistake between my personality and my attitude.
    My personality is who I am. My attitude depends on who you are.
  1. vcarvepro
    By rljk in forum PhotoVCarve and VCarve Pro
    Last Post: 08-28-2017, 12:13 PM
  2. CHinese Text available in VcarvePro
    By Mr.Chips in forum Vectric
    Last Post: 05-13-2017, 12:01 AM
  3. HELP !! VcarvePro v8.509 NEWBIE
    By Macguitar in forum PhotoVCarve and VCarve Pro
    Last Post: 10-10-2016, 11:49 AM
  4. drawing problem
    By shimmwagen in forum GibbsCAM
    Last Post: 04-06-2012, 06:29 PM
  5. Problem with drawing? or CAM?
    By CNC Darren in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-05-2005, 06:30 PM
