585,764 active members*
4,076 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > Want To Buy...Need help! > Need help bying a compact 5 axis milling machine.
Results 1 to 14 of 14
    Feb 2021
    9
    Hello!
    I'm looking for a compact 5 axis mill for machining medical prototypes (for a business not a hobby) that's capable of machining stainless steel mainly ( in some cases titanium but not a priority right now though) and also capable of machining parts that are between 150 and 200mm length. My budget is relatively humble and is around 40k dollars (50k dollars max if necessary). Can you give me some tips and suggestions please?
    Any help is welcome.
    Thanks in advance.
    Dec 2013
    5717
    Re: Need help bying a compact 5 axis milling machine.
    Jim Dawson
    Sandy, Oregon, USA
    15362
    Looks good but a light weight at 300lbs this would be a concern for something that will be well over $50k
    May be a used Datron 5 axis would be a better deal
    Mactec54
    Feb 2021
    9
    Thank you Jim Dawson and mactec54 for your answers, i came across the TN5-V6-TC8 and i found 50k for that machine is a bit too much. The machine needs to be new unfortunately (some bs laws in my country).
    Dec 2013
    5717
    Given that you must buy a new machine, the TN5-V6-TC8 is the only 5 axis machine for <$50K that I found. A Haas TM1 with 5 axis is about $75K. You might be able to find something in China for less money.
    Jim Dawson
    Sandy, Oregon, USA
    Feb 2021
    9
    thank you, i just saw that HAAS has a mini mill starting at 29k euros with an option of 5 axis rotary at about 18k euros, what do you think?
    Dec 2013
    5717
    The Haas mini is a nice machine. I have a Haas and love it. But the 5 axis option is for the drives and wiring only, does not include the rotary table hardware, that is an additional $20K to $37K
    Jim Dawson
    Sandy, Oregon, USA
    Feb 2021
    9
    i see, so basically the mda precision one is my only choice?
    15362
    Quote Originally Posted by R_mantis View Post
    No there are many others you just have to spend some time looking how big are your biggest parts going to be
    Mactec54
    15362
    Every CNC Machine manufacture builds a 5 axis machine and some would be in your price range
    This will do quite well also https://makezine.com/2013/09/23/pock...five-axis-cnc/
    https://www.moderntool.com/products/...hining-center/
    https://www.doosanmachinetools.us/ma...enters/dnm-5ax
    Mactec54
    Dec 2013
    5717
    The Doosan DNM-5AX machines would be in your size range, but I think would be out of your budget. No on-line pricing is available, you would need to contact your local distributor for pricing.
    The only other thing I can think of would be to buy a Tormach 1100MX and add the 4th and 5th axis yourself.
    https://tormach.com/machines/mills/1100mx.html
    Search for ''5 axis trunnion table''
    Jim Dawson
    Sandy, Oregon, USA
    considering the budget I'd say Jim's pretty much right with a tormach (or a mill of the sort) . The mill is cheap enough , a rotary is cheap enough , and it's dead simple to build a platform that you can plunk another rotary onto . Obviously the 1st rotary will be limited in it's rotation without wrapping the wires from the second rotary , but it's easily doable . Only thing is you may need is to setup with a different control software since pathpilot appears to be limited to 4 axis . Pathpilot is built on linuxcnc , so the linux group may be able to help you to get pathpilot setup with both rotaries or setup with linuxcnc , either way both are great softwares
    In my opinion it's a much better and more solid option for prototyping than any of 5 axis rigs that fall within your budget .
    Sep 2005
    1195
    Feb 2021
    9
    Thank you all infinitely for all the suggestions, i'll definitely check them out and continue looking and i'll keep you all updated
    any other suggestion is always welcomed.
    Thanks again.
  1. Emco Compact 5 cnc with milling attachment
    By sticksman in forum EMCO Lathe
    Last Post: 08-13-2017, 06:50 PM
  2. Looking for advice on bying a cnc mill machine
    By 357supermagnum in forum Want To Buy...Need help!
    Last Post: 11-16-2014, 01:51 PM
  3. MRF 3 axis milling machine
    By wjnagel in forum Mechanical Calculations/Engineering Design
    Last Post: 02-13-2013, 10:49 PM
  4. DIY 3 axis CNC Milling Machine.
    By Eagle23 in forum Uncategorised MetalWorking Machines
    Last Post: 10-20-2009, 02:20 AM
  5. How many axis to DRO on a Milling machine?
    By hotponyshoes in forum Uncategorised MetalWorking Machines
    Last Post: 05-15-2007, 08:16 AM
