584,837 active members*
5,591 visitors online*
IndustryArena Forum > Tools / Tooling Technology > Calibration / Measurement > A calculator for measuring bore diameters using three gage pins
Results 1 to 2 of 2
    Sep 2017
    3
    After some discussion on another machining forum, I created a web-based calculator for calculating the diameter of a bore based on the diameters of three gage pins (or any other cylinder) that fit into it.
    It's free, open source software that I built as a side project in my spare time. I wanted to show it to the CNCZone community, hopefully it's of use to someone!
    You can access it here: https://www.holecalc.com
    Let me know if you have any feedback or issues!
    Jun 2015
    4131
    Re: A calculator for measuring bore diameters using three gage pins
    hy this method was heavily used into inspection areas, that used to use sets of gage pins with increments of 0.01, 0.005, or even less; required hand's sensitivity
    method was tough, but it started to loose ground a few decades ago
    what you did is ok, just keep it up if you like to go that way
    if you wish to go futher, "down the hole", then try to think about calculating a diameter, using :
    ... 3 points from a ( normal ) probe
    ... 2 points from a probe that is sensitive to cosine directions / kindly
  1. Replies: 1
    Last Post: 11-01-2019, 07:05 PM
  2. Dose anyone make Precision Height Gage Pins
    By bcnu in forum Calibration / Measurement
    Last Post: 08-07-2017, 06:32 PM
  3. machining of small bore diameters including face grooving and profiling
    By jgarner77 in forum Material Machining Solutions
    Last Post: 11-09-2013, 10:30 PM
  4. Weird Question 'bout Gage Pins and Thru Holes
    By eliot15 in forum MetalWork Discussion
    Last Post: 10-19-2011, 12:00 AM
