585,956 active members*
4,530 visitors online*
    Dec 2015
    34
    axis settings/tuning cnc router
    I have 200 step per unit motors.
    drivers are set to 1600 steps per revolution
    Ball Screws are as follows:
    Z axis 5mm lead x 15mm diameter (direct drive)
    X axis 6mm lead x 19mm diameter (direct drive)
    y axis 6mm lead x 25mm diameter ( this is driven by a belt drive under the gantry)
    Apr 2004
    5737
    Re: axis settings/tuning cnc router
    The motors are 200 full steps per revolution, not per unit. 1600 steps per revolution would be a correct setting if you were using 1 inch per revolution screws and 8x microstepping. But it doesn't sound like that's the case.
    Andrew Werby
    Website
    Dec 2015
    34
    Quote Originally Posted by awerby View Post
    The Ah-Ha motor controller is set at 1600 steps per rev, or eighths. So what is the case? How do I determine my base settings. I can switch the motor controller to quarter, half and full steps as well.
    Apr 2004
    5737
    The idea is to express a unit - in your case, I'm assuming that would be a millimeter, in terms of steps, or whatever microsteps you want to use. The pitch of a screw is how far it advances the nut with a full revolution. So, to take the example of your Z axis screw, with a 5mm pitch, a full revolution of 200 full steps would advance it 5 mm. Therefore 40 full steps would advance it one mm. If you apply a microstepping factor of 4 (quarter-steps), that makes 160 microsteps per unit. If that's what you're happy with in terms of resonance reduction, that's what you'd set your controller to. The same logic applies to your other screws, which have 6mm pitch. If you're using a belt drive with pulley reduction, then you have to take in that reduction factor into account as well.
    Andrew Werby
    Website
  1. Motor Tuning Settings
    By Rhawkbw in forum Machines running Mach Software
    Last Post: 11-20-2012, 09:24 AM
  2. Stepper Motor Tuning / Settings in Mach3
    By Rob37 in forum Controller & Computer Solutions
    Last Post: 11-04-2010, 02:59 AM
  3. what are your motor tuning dialog settings at?
    By surrealism in forum Taig Mills / Lathes
    Last Post: 06-18-2010, 10:35 PM
  4. motor tuning settings on new vfd
    By billmiller in forum Shopmaster/Shoptask
    Last Post: 05-28-2010, 11:05 AM
