585,754 active members*
4,225 visitors online*
Results 1 to 2 of 2
    Dec 2003
    189
    Need suggestions on large scale 3d printer build
    So, I'm not a newbie to CNC and have a decent DIY CNC mill that will do aluminum and some small steel parts.
    My work involves casting glass into a mold tp produce sculptures. They are life size so figure a printable footprint of 3 feet, by 2 feet by 1 foot.
    Any good kits out there with all the goodies? I can get 80/20 or steel locally and am good with drives/steppers/servos etc.
    Where should I start?
    Is a sentance fragment?
    Apr 2004
    5735
    Re: Need suggestions on large scale 3d printer build
    So your plan is to make positive forms in sections that you can pull molds off of in a material that can handle hot glass being poured into it? I'd like to see pictures of this process, once you've got it working. Is there a reason you have to print them and can't carve them with a CNC machine?
    As for the printer you want to build, I'd start by looking at large-scale printers that exist already, like the Gigabot X: https://re3d.org/gigabot/ I like the idea of a printer that can use pellets instead of filament, since filament is not just expensive but a hassle to deal with. A large extruder nozzle size also helps when making large parts. The frame isn't too different from that of a CNC router, and it uses profile rails, but printers tend to use belt drive rather than screws or R&P. Speed is emphasized more than rigidity, although more stiffness doesn't hurt. I'm not sure if anyone is offering large-size printers in kit form, but you could probably build your own frame, provide your own motors, motion control parts and electronics, and just buy the parts you can't make yourself economically.
    Andrew Werby
    Website
  1. Build your own large format printer?
    By rackbox in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 09-22-2016, 06:25 PM
  2. Replies: 1
    Last Post: 10-02-2015, 05:34 AM
  3. Large Scale RepRap style printer
    By Benonymous in forum 3D Printer / 3D Scanner Discussion
    Last Post: 11-11-2011, 06:22 AM
  4. Looking for a large scale Fabricator
    By MVJKstudio in forum Employment Opportunity
    Last Post: 08-05-2010, 08:03 PM
  5. Heavy large scale gantry mill/router/3d carving 5 axis build
    By Tristar500 in forum DIY CNC Router Table Machines
    Last Post: 03-18-2010, 12:07 PM
