585,932 active members*
3,808 visitors online*
    Feb 2021
    Question LC6090 Wiring into Laser Power Supply
    Hello everyone! I'm brand new to the forums, and to laser cutters in general, so hopefully I've put this post in the right place, but please correct me if there's a better group for it. :-)
    I've got a G.Weike LC6090, and I need to put a new laser power supply in it; we upgraded from an 80w tube to a 100w, and it is my understanding that we need the bigger PSU to drive it properly. I'd like to make sure that the leads coming out of the four-lead D-sub connector and two wires from the safety cutoffs are going to the right pins in the wiring block -- H, L, WP, G, IN, 5V -- before hooking everything up, and after a couple days of searching I have not been able to find a clear schematic of which should go where. Does someone here hopefully have a pointer towards this info, or might someone please be so kind as to snap a quick picture of the wiring connections on the laser PSU in their machine?
    Thank you very much in advance!
    Re: LC6090 Wiring into Laser Power Supply
    If your gweike laser is purchased in the year of 2021, the PSU for 80w tube and 100w tube is same, so you only need to upgrade your laser tube, do not need to change PSU.
  1. Need help diagnosing a laser power supply wiring
    By coreman in forum Laser CO2 Tubes, Diodes, RF and Power Supplies
    Last Post: 12-13-2015, 09:53 PM
  2. Laser engraver power supply wiring help needed
    By 57harvey in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-08-2014, 04:12 AM
  3. suke laser sk500 power supply wiring problem
    By Foxoby in forum Laser CO2 Tubes, Diodes, RF and Power Supplies
    Last Post: 05-01-2013, 08:18 PM
  4. laser power supply wiring help
    By Ed Williams in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-18-2010, 02:26 AM
  5. AC Wiring to Power Supply
    By blue_steel in forum CNC Machine Related Electronics
    Last Post: 12-02-2008, 04:51 AM
