585,996 active members*
4,222 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > MPG Handwheel Pulse Multiplier
    Oct 2007
    7
    Hello. I'm using a Chinese 80mm 100pr 5 volt MPG Handwheel to directly pulse the stepper drivers on my CNC mill system. Making a "fly by wire" method to jog/move mill axis bypassing the software controls.
    The steps are actually too fine, and I do not want to alter the pulse per revolution that the stepper drivers are set at. Does anyone know a method that will multiply the step output of the MPG handwheel? Ideally a method to switch select x1, x10 or x100 would be great.
    Arduino solutions are fine if someone could point me in the right direction.
    Sep 2016
    50
    Quote Originally Posted by cgabel View Post
    I’m also looking for a similar solution, i'm building a lathe with a ballscrew for both feeding manually and a controller for threading, a switch to chose between manual or threading,
    The encoder input to an arduino, multiply the pulses to a stepper driver that matches with steps/rev for different resolutions to be able to jog the machine fast and then go back to fine “calibrated” resolution,
    Anyone have some code who does this?
  1. Step Pulse Multiplier
    By RotorRouter in forum Gecko Drives
    Last Post: 08-02-2010, 07:00 PM
  2. G903 Step Pulse Multiplier Board?
    By The_Doctor in forum Gecko Drives
    Last Post: 05-05-2008, 06:29 PM
  3. G340 step pulse multiplier
    By pescado_loco in forum Gecko Drives
    Last Post: 01-13-2008, 02:46 AM
  4. pulse multiplier
    By Beyazbalina in forum Stepper Motors / Drives
    Last Post: 03-25-2007, 10:37 AM
  5. Am I going to need a pulse multiplier for this setup?
    By WoodSnarfer in forum Gecko Drives
    Last Post: 02-17-2005, 04:19 AM
