585,981 active members*
4,111 visitors online*
Thread: Turbojet
Results 1 to 8 of 8
    Feb 2007
    20
    Turbojet
    This is a link to a video of a turbo jet I designed in solidworks. When I go back to school I plan to make a model of the jet with a rapid prototyping machine. I am also thinking of making a working model of the jet in the machine shop at my school. I ordered a book on jet engines but I have not received the book yet so my design so far is based on very limited knowledge. It is in the first stages of design once I study the book I will finalize the design. I still have to design the flame box, and many other components. I limited the number of air foils because it will be difficult to manufacture large quantities of airfoils. Does any one think the airfoils should be closer together.
    http://video.google.com/videoplay?do...arch&plindex=1
    Feb 2007
    20
    Jan 2006
    481
    Feb 2007
    20
    I order a book about one month ago on jet engine construction but still have not received it. I do not know how the rest of the jet works so i am stuck for a while. I am going back to school next Thursday and i will make a plastic prototype of the airfoils in the STL machine. Can someone explain how the flame holder works so I can design one.
    Feb 2007
    20
    Made prototype models of my compressor and turbine blade design on STL machine.
    http://s236.photobucket.com/albums/ff157/klaustigman/
    Feb 2007
    20
    I have the ability to machine the airfoils but I do not have the ability to engineer
    the airfoils to make an effective jet. There are also many other aspects that I am not qualified to engineer. I also do not have the capabilities to machine a shaft within the tolerances needed. At such a high speed that the engine would
    run at everything would have to be concentric and perfectly balanced for the engine to function properly. I am abandoning the project because it is beyond my capabilities. This is a project for a fully qualified engineer.
    Jan 2006
    481
    Re: Turbojet
    those are cool. any one use cnc machined turbine wheel
    5 axis CNC Machining Center -JPM
    [email protected] www.jackpowermodel.com
  1. U-22 Turbojet
    By woodythx13 in forum Hobby Discussion
    Last Post: 08-25-2009, 08:17 AM
  2. Home made turbojet
    By Joelwhitton in forum Hobby Discussion
    Last Post: 01-07-2008, 03:27 PM
