585,978 active members*
4,391 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > Cutter comp in the yz plane
    Dec 2008
    12
    Is there a way to use cutter comp in the yz plane?? Whether programming g code or conversational?? I have a 90 degree head in my machine and I've reached out to hurco and they tell me that this isn't possible. Is this really true or is there a trick into fooling the machine into doing it?? Any help would be greatly appreciated.
    Sep 2002
    1955
    Re: Cutter comp in the yz plane
    Did you try G19?
    I don't see why you couldn't do what you want. I've used comp in the YZ plain on Fanuc machines. A little difficult starting and stopping it. I think what I did was to turn it on with a simple vertical move in Z.
    I believe it's correct to say that if an arc is fully described with a complete address, XYZ (I,J,K) it will move correctly no matter what work plain is active when the arc is called. In this case you're going to need Y and Z and J and K addresses in your arc calls.
    I've done a lot of chamfering with full ball mills in the YZ plain. Pretty mind scratching doing it without CAM completely holding the reins. But fun to figure out. To make it easier I would program to the center of the ball.
    Don't be surprised if you need G42 where you think you need G41. Seems I never would get it right the first time. Learned the hard way with a few broken tools.
  1. Replies: 3
    Last Post: 10-08-2018, 11:52 AM
  2. Help required: 2D DXF to NGC in XZ plane for foam cutter
    By Harmonitron in forum LinuxCNC (formerly EMC2)
    Last Post: 06-09-2011, 01:40 PM
  3. cutter comp help...
    By forsale78 in forum Community Club House
    Last Post: 08-09-2010, 07:32 PM
  4. Cutting bed is out of plane with the cutter
    By hualon in forum DIY CNC Router Table Machines
    Last Post: 06-22-2008, 05:28 PM
  5. Cutter comp on an id hole< cutter diam.??
    By PaintItBlue in forum Haas Mills
    Last Post: 05-06-2008, 12:30 AM
