586,000 active members*
4,956 visitors online*
IndustryArena Forum > CAM Software > EnRoute > How to get nice chamfer cut on 5052 Aluminum with a Vortex 3855 bit
    Jul 2017
    4
    I have a Biesse Rover Plast J CNC router and been having such a difficult time cutting aluminum on that machine as it is (usually can only do 1/32" depth per pass) but the other day we bought a bit that was highly recommended by an experienced machinist [Vortex 3855--90 Degree V-Point, 1/2 Dia] for chamfering aluminum yet the cut looked atrocious. The cut was very rough and bumpy as if I tried to cut it with a saw blade.
    Using Enroute 6 for toolpaths, we are just going down about 1/16", 2 passes, 100 in/min feed, 50 plunge, 18000 rpm, conventional cut into 1/4" 5052 aluminum. Any advice on how to get a better cut? I hear 6061 is much better for machining but its also about $200 more expensive in my area so if its possible to get a better cut going in 5052 I'd love to hear it. We have various lubricants that we use while milling and also blow chips out of the way with compressed air.
    Bit link:
    https://carbideprocessors.com/90-deg...k-vortex-3855/
    Also if you have any advice for being able to cut deeper per pass on 5052 using an Amana 51480-Z Single O Flute [https://www.toolstoday.com/v-14287-51480-z.html] I'd be grateful to hear some suggestions. Currently our settings for that tool, for cutting through 1/4" 5052 aluminum are 5 passes, 100 in/min feed, 50 plunge, 18000 rpm, climb cut with lubrication applied manually.
    Thanks!
    Re: How to get nice chamfer cut on 5052 Aluminum with a Vortex 3855 bit
    sounds like it's gouging , conventional milling vs climb might reduce or resolve this
  1. Need a little advice on cutting 5052 aluminum on router table
    By beeman_mccheyne in forum MetalWork Discussion
    Last Post: 11-14-2014, 05:04 PM
  2. RFQ: 250 pieces 5052 aluminum bar stock + 2 dowel pins
    By ahk199 in forum North America RFQ's
    Last Post: 02-14-2013, 02:08 AM
  3. Cutting 5052 Aluminum
    By edwardpic in forum DynaTorch
    Last Post: 03-15-2009, 05:53 PM
  4. Burr Free drilling in 5052 aluminum
    By Texiwi in forum MetalWork Discussion
    Last Post: 06-11-2008, 10:07 PM
  5. How to get a nice finish in aluminum?
    By Zumba in forum Mass finishing equipment/media/strategies
    Last Post: 04-26-2006, 12:50 PM
