585,585 active members*
4,313 visitors online*
    Sep 2006
    25
    z zero problem
    I am running mach3 BOB PMDX-122 Gecko drive G203v.
    been running for a few years with no problems.
    just had a problem popped up i went to zero to the table top using the zero plate
    when i ran the zero. The spindle moved down but did not stop when it touch the plate. have to hit the page up for it to go back up.
    any idea where to start looking to correct this?
    Paul
    Re: z zero problem
    Make sure the Probe LED lights up when you touch the plate to the bit.
  1. Replies: 1
    Last Post: 11-24-2017, 03:56 AM
  2. Fadal Idler problem. Rpm pulse problem
    By complextool in forum Fadal
    Last Post: 10-07-2016, 06:28 PM
  3. Tube problem or powersupply problem? Help you to check out
    By Melody-gweike in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-05-2012, 04:09 AM
  4. daewoo puma 12lb tape format problem/parameter problem
    By robb12877 in forum Daewoo/Doosan
    Last Post: 08-25-2011, 06:13 AM
  5. Replies: 5
    Last Post: 08-04-2010, 11:33 PM
