I need help, I have a Deckel Maho MH600W with Heidenhain TNC 425. The buffer buttery died and clear all machine parameters.
Can e
Can e
Hello, I hope you are having a good day. I had the same problem as you, all the parameters were deleted because the buffer batteries were discharged. I entered the parameters manually by entering the 95148 code, but it gives the error "red mp not correct" and the workbench keeps failing. Probably general parameters, nc parameters, cnc parameters were also lost. Can I get the files with the parameters (I don't know which ones) with TNCRemo from you? Or a backup file.
