585,927 active members*
3,876 visitors online*
    Aug 2007
    7
    Help! Dnc setting for Mitsubishi 500 series
    My friend just bought a second-hand Feeler FV-800 cnc machine (made in Taiwan) with Mitsubishi 500 series controller. I'm trying to set up DNC for him but unsuccessful. Does anybody have the operating manual for this controller or know the setting parameter for both PC and controller ( such as baud rate, parity, data bits, stop bits, flow control)?
    Thank you in advance.
    Any suggestion will be greatly appreciated.
    Jan 2007
    333
    IO DEVICE PARAMETERS #1
    Parameter -------- Value
    2 ---------------- 2 (4800)
    3 (stop bits) ----- 3 (two stop bits)
    4 (parity enabled) - 0 (No)
    5 (parity) --------- 1 (Even)
    6 (data bits) ------ 3 (8 dat bits)
    7 (terminator typ) -- 3 (EOR)
    11 (handshake) ---- 3 (DC codes)
    12 (parity on DC) --- 1 (Yes)
    IO PARAMETERS SCREEN #2
    Parameter ------- Value
    1 (DC2 and DC4) -- 1 (DC2 only)
    2 (CR) ------------ 1 (Yes)
    3 (EIA output) ---- 0 (No, ISO)
    7 (Timeout) ------ 200 (200 sec)
    Aug 2007
    7
    Bborb:
    Thank you very much for your reply. I still have some doubts.
    1.Can I set the baud rate for CNC machine to 9600 instead of 4800?
    2. What's the parameter setting for computer serial port COM1?(I'm using Windows XP. By default, baud rate: 9600, data bit: 8, parity: none, stop bit: 1, flow control: none)
    3. In DNC software(cimoedit), there is some setting about CNC machine. Do I have to set all the parameters exactly same as the CNC machine setting which you suggested?
    Thank you again.
    Regards
    Jan 2007
    333
    Hi koeitool,
    My DNC software came pre-configured for the Mits 500 control and the settings I posted were the default settings from Mitsubishi (I believe).
    You CAN change the settings in your machine AND in CimcoEdit but they MUST match each other.
    I would try changing ONLY the baud rate in your machine, then change CimcoEdits settings to match.
    CimcoEdit should be set to:
    9600=baud
    8=data bits
    Even-parity
    2=stop bits
    Xon/Xoff=handshake
    ISO=(if applicable)
    _
    Don't worry about what XP has settings for the comport EXCEPT you want to turn off Fifo support. CimcoEdit's settings override what is in XP's control panel hardware settings.
    May 2015
    12
    Re: Help! Dnc setting for Mitsubishi 500 series
    HELLO EVERYONE I HAVE PROBLEM IN SEND PROGRAM TO MACHINE MITSUBISHI 530 SERIES VIPER 1500 ALARM P1 MODE MISMATCH
    ANY IDEA
  1. Mitsubishi MV Series Wire EDM
    By william18 in forum EDM Discussion General Topics
    Last Post: 10-18-2019, 06:45 PM
  2. Mitsubishi SB series EDM Parts
    By dogwood8488 in forum EDM Discussion General Topics
    Last Post: 12-20-2013, 01:00 AM
  3. MITSUBISHI MELDAS 500 SERIES
    By el gordo in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-23-2013, 12:33 PM
  4. Setting up Mitsubishi Amp & servo with Mach3
    By thunderbite in forum Machines running Mach Software
    Last Post: 05-29-2012, 02:45 PM
