585,991 active members*
6,597 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > New to me 89 Fadal VMC40
    Jun 2004
    22
    Sorry this is a bit new to me. I've have several benchtop type machines. This is my first "real" cnc machine.
    I'm having a weird issue. XY and Z only move 50% of what it is supposed to .
    I.E. if I jog 4 inches it only moves 2 inches. On all 3 axis.
    This also appears to affect the TC,1 command the z does not move heigh enough to change out tool holder.
    Brad
    Oct 2008
    1632
    Re: New to me 89 Fadal VMC40
    Use SetP and go verify all your settings are correct for your machine. Many of these older Fadals have bad batteries and loose the settings after awhile being not used.
    If you open the pendant rear cover (Monitor / operator panel) there should be a sticker with all the factory settings.
    Next, after you do this, make sure all the marks are aligned and you do a CS command (Cold Start) It's pretty important in order to establish it's soft limits per axis.
    Let us know what you find. Ah, make sure your balls screws are also set right Metric versus Inch.
    Richard
  1. Good Buy Fadal VMC40
    By kunz82414 in forum Fadal
    Last Post: 03-16-2018, 05:54 PM
  2. Fadal VMC40 Z Amplifier Card
    By NE748 in forum Fadal
    Last Post: 07-07-2017, 02:08 PM
  3. 4th or 5th axis on Fadal VMC40 idea.
    By RDTS in forum Fadal
    Last Post: 11-15-2008, 06:54 AM
  4. Just ordered Fadal VMC40
    By bherr in forum Fadal
    Last Post: 10-27-2006, 01:27 PM
