586,005 active members*
5,034 visitors online*
    Mar 2021
    7
    NVCM - outputs not functionning
    I have the NVCM6V2.1 board and I'm using Mach3.
    I'm trying to set an output and control it using M11/M10 but for some reason it does not succeed.
    What I've done so far: I have connected output TX16 to my laser module and defined it as output6 in Mach.
    For the test - If I'm setting the coolant to out 6 it can start and stop the laser, SO I know all electronics is connected fine. the pin is correct and output 6 is set properly.
    BUT...
    When I'm trying to use m11 command it does nothing. (tried all kind of syntaxes including the ones that includes movement like M11P6 G0 X100)
    How do I trigger outputs on the NVCM via Gcode?
    BTW,
    Just for the test, I created a new profile in Mach based on my current one and replaced the breakout board with an old LPT one that I have and there M11 does work so I assume mach's macros are ok (cannot use that board because it is short on ports)
    Gil
    Apr 2006
    3498
    Re: NVCM - outputs not functionning
    I trashed these boards ( had two of them ) , purchased UCCNC AXBB-E for my 4 axis and RosettaCNC for my 5 axes...
    http://free3dscans.blogspot.com/ http://my-woodcarving.blogspot.com/
    http://my-diysolarwind.blogspot.com/
    Mar 2021
    7
    Quote Originally Posted by Khalid View Post
    I'm half way there ....
    Took this board off and connected my old, 1st lpt 5$ board and it is already better....
    Mar 2019
    Quote Originally Posted by gilur View Post
    The outputs are open collectors you need pull-ups and a power supply
  1. Novusun NVCM Motion Controller Enable PWM
    By sam19090 in forum Controller Cards
    Last Post: 12-29-2020, 03:57 PM
  2. Need More Outputs
    By Atomic_Sheep in forum DIY CNC Router Table Machines
    Last Post: 11-06-2016, 01:39 PM
  3. Need More Outputs
    Last Post: 11-06-2016, 06:52 AM
  4. G32 outputs E instead of F
    By Xeno in forum Mastercam
    Last Post: 01-22-2013, 06:41 PM
