I am in the beginning process of converting a Sieg X2D mini mill to CNC. I have a SainSmart CNC 4 Axis Kit with ST-4045-A1 drivers and a Mach3 USB Motion Card (STB4100) to connect to PC. The stepper motors are NEMA 23 270oz-in. I am a total beginner to this but I was able to get the steppers turning on the work bench. The issue is the motor shafts will only turn about 1-1/4 revolution while I hold the direction key down (jog). It does the same on all 3 axis. If I type in a command in the MDI screen, it will do what it is told (G0 X125.5 - no problem). If I load a g-code file and cycle start - it will do what it is told (at least it shows on the screen). The motors turn and change direction indicating to me that it is getting the commands and doing what it is supposed to - It just won't jog beyond 6.6703mm on the DRO. 6.6703 is the magic number.
Any help would be appreciated. Hopefully, it is a configuration issue that is fixable. I am using the configuration file that came with the kit.
Michael
