585,737 active members*
4,627 visitors online*
Results 1 to 11 of 11
    Apr 2013
    63
    RFQ Wear resistant nylon turned/interpolated parts TX USA
    Good afternoon-
    I'm seeking a quote to have these two parts made, in qty of 10 each and 20 each. They are made of wear resistant nylon, similar to McMaster 8733K818.
    PDF attached below. I can provide models if needed.
    Thank you
    Apr 2013
    63
    Re: RFQ Wear resistant nylon turned/interpolated parts TX USA
    Sorry... email address for contact is
    [email protected]
    Jun 2010
    4256
    I can't help feeling that the only way to make the parts as drawn reliably and at a reasonable cost would be injection molding. Those thin walls would flex something awful if you tried to turn them.
    You might succeed if you made up mandrels for holding the parts during turning. There would be a significant up-front cost for that work regardless of the results.
    I think I can see what the parts are meant to do, but I have to ask why. If you are replacing existing parts, go back to the original supplier - who probably has them molded. Otherwise, I would suggest a serious redesign, using O-rings. A redesign taking the material properties into account.
    Just trying to be helpful, as I have machined plastics to fine tolerances.
    Cheers
    Roger
    Apr 2013
    63
    Hi Roger - thanks for the input.
    Looking again at the drawings, perhaps we don't need such a tight callout on the OD, just a limit dimension on the OD that it's no smaller than x.xxx and allow a larger variation above that of +.005" or possibly even +.010"?
    I guess I'm asking what is a reasonable tolerance to get a fairly reasonable price, if you don't mind advising?
    The original parts are turned, but these are a modification at a different size, so we can't get them from the OEM.
    Steve
    Jun 2010
    4256
    Turned? In nylon, with such thin walls and no mandrel? I have my doubts.
    Machine out the interior from stock of a bigger OD, then part off at the right size.
    Mount on a mandrel of the exact shape and size, then machine the OD.
    You would need the precision mandrel first.
    I doubt your chances at less than $50 each.
    I am not bidding.
    Cheers
    PM sent
    Over 30 year in cnc machining parts business.CNC Turning, Milling, Drilling, Planning, Grinding, Welding www.plusminusthree.com Email:[email protected]
    Jul 2018
    6321
    Hi X35 - Plus nylon changes size the day after you machine it. Temperature and humidity changes - size changes so if this is intended for liquid contact I would recommend soaking it in that liquid for a couple of days before you machine it. We do that for yacht rudder bearings in any plastic that is used. Nylon is the worst for dim changing... Peter
    15362
    Quote Originally Posted by X35 Design View Post
    Steve
    Should not be a problem to machine as they are in your first request, they already have a large tolerance I would of given you a quote but will not be available for a few weeks
    You could use Delrin as well which would be better for wear than the nylon
    Mactec54
    15362
    Almost all plastics can change size due to humidity, it is quite obvious what these parts are for, so would not be a problem being such a small part as well
    There are many materials that you should be using that is better suited for your yacht rudder bearings Nylon is a bad choice of material for those parts
    Mactec54
    Mar 2021
    I'm glad to hear that you have a project to quote. So would you able to send me the 2D files and 3D files ( In step or IGS format)& material|QTY|surface finish details for your project?
    My email adress: [email protected]
    After receiving your files and project details, we will offer you a competitive price.
    Looking forward to your email.
    Celia Chen
    Prototyping | CNC machining | Injection Molding | 3D printing | Vacuum Casting
    Apr 2013
    63
    Hello again-
    I had a quote from someone in NY state, but the CNCzone messages we had are now gone from my cnczone account.
    My client is ready to buy some, if you could please PM or email me that would be very helpful.
    Thanks!
  1. Parts - engraving nylon wheels
    By SlickOpps in forum Questions or Problems
    Last Post: 02-20-2019, 02:19 AM
  2. Small Nylon Parts
    By musall37 in forum North America RFQ's
    Last Post: 03-14-2013, 04:04 AM
  3. Basic Turned Nylon (maybe Delrin)
    By LateNight72 in forum RFQ (Request for Quote)
    Last Post: 09-19-2011, 11:51 PM
  4. RFQ - Turned Delrin/Nylon/Aluminum
    By AuroraDrvr in forum Employment Opportunity
    Last Post: 03-03-2009, 07:05 AM
