585,758 active members*
4,367 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Huanyang GT series VFD speed control, UC300eth and uccnc
    Sep 2014
    7
    Hey everyone,
    I'm setting up my VFD and spindle... both 2.2kw 220v and I have a question in regards to speed control. I tried looking for the answer without any luck... I'm able to control the speed with the potentiometer with the jumper installed on J1 1-2 but uccnc won't control the speed. If I remove the jumper from J1 obviously the potentiometer stops working but I can control the speed with uccnc. Is there a way to have both working simultaneously?
    Also, what can cause the VFD to not be able to control the spindle in vector mode?
    15362
    Re: Huanyang GT series VFD speed control, UC300eth and uccnc
    Quote Originally Posted by frank_n View Post
    Hey everyone,
    The Vector control does not work for these High frequency spindles
    The J1 jumper should always be in one of the positions it should not be removed completely
    You can't have both, Pot ( manual ) control is when you use the Key pad, remote control the pot does not work although I found a way to make it work on a regular Huanyang VFD Drive I will check and see but normally you can't have both
    Mactec54
    Sep 2014
    7
    Thanks for the info Mactec54...
    Explains why I couldn't get it to work with the vector control turned on.
    The J1 jumper had two jumpers installed... it's a 4 prong jumper. When I removed the top jumper that's when I was able to control the speed from uccnc but lost control from the potentiometer.
  1. MX4660 Speed Control for 2.2 KW huanyang vfd
    By Dekman in forum Leadshine
    Last Post: 06-27-2022, 10:10 PM
  2. Help with UC300ETH-C76 and UCCNC?
    By mchesney1 in forum UCCNC Control Software
    Last Post: 10-04-2020, 10:27 PM
  3. Huanyang VFD speed control
    By morfeus80 in forum Spindles / VFD
    Last Post: 01-07-2019, 02:25 PM
  4. Not getting any input from PC to CNC Router - UCCNC UC300ETH UB1
    By crash416 in forum DIY CNC Router Table Machines
    Last Post: 11-03-2017, 12:49 AM
  5. UCCNC and UC300ETH - A real scary speed monster.
    By A_Camera in forum UCCNC Control Software
    Last Post: 11-24-2016, 06:21 AM
