V23 build 1493
I’m trying to Mill 3 axis Slice Planar on round stock via A axis (substituting the Y) and am receiving the following error codes:
- Surfer Error 64: Invalid Input Data Buffer
- Security Error 4
- Access Denied
- Zcut Module Error 8: Data Transfer Error
Ultimately I’m trying to do chess pieces, but have simplified a pattern to just a v-groove surface wrapped on cylindrical stock in efforts to troubleshoot this, yet I still get the errors. Sometimes when I go to compute the paths and after receiving the errors, the Milling Stock will have changed to Rectangular Stock and be grayed out, not allowing Cylindrical Stock to be chosen.
This is the first time I’ve tried to use this portion of the software in the 11 +/- years I’ve owned it, so I might be doing it wrong, but I’ve successfully posted a simple pocket on a cylinder, so I think I’ve got the basic gist of it. Of course v23 isn’t supported anymore, so BC just wants to sell me the new version, and while I am tempted, I want to exhaust other efforts in making this version work first.
I came across an old thread with one the same error messages as mine, where someone was trying to post Mill 3 Axis operations, and it appears the fix was updating from build 1493 to build 1812, so my initial thought would be to see if anyone knows where I can find the 1812 v23 update file?
Other than that, I’m open to any other remedies others could recommend or possible errors I may be making.
Thanks in advance!
Frank
