585,743 active members*
5,069 visitors online*
Results 1 to 2 of 2
    Mar 2019
    18
    rznc-0501 4th (c) lathe axis
    hi, i have this control board running(picture attached), i tried to wire another stepper to c axis and give it some gcode with 4th axis generated with rhinocam.
    now the new stepper not act like a 4th axis but move together with y axis, so i assume they made that slot for machines which need double y axis motors. but thinking maybe it's from firmware or maybe it's gcode.
    so wanted to ask, if i upgrade firmware is it possible to use that c axis as 4th axis?
    if not, a 3 axis lathe still will be useful for me, what is the best way to use x, z and lathe axis and easily switch back to x, y, z axis?
    gcode is here also if you think it's faulty, it's just for simple cylinder:
    O 1000;
    N1 G00 G17 G40 G49 G80 G90 G98;
    (4th Axis Parallel Finishing)
    N2 G21 T1 M06;
    N3 G90 G00 X0. Y0. S0 M03;
    N4 G43 Z13.071 H1;
    N5A0.F10.000005
    N6G01Z5.A0.F1125.
    N7X20.A0.F1000.
    N8Z4.997A-8.6F1000.
    N9Z4.985A-17.1F1000.
    N10X0.A-17.1F1000.
    N11Z5.A-21.4F1000.
    N12Z4.987A-25.7F1000.
    N13Z4.999A-34.3F1000.
    N14X20.A-34.3F1000.
    N15Z4.996A-42.8F1000.
    N16Z4.978A-51.4F1000.
    N17X0.A-51.4F1000.
    N18Z4.999A-57.9F1000.
    N19Z5.A-68.6F1000.
    N20X20.A-68.6F1000.
    N21A-79.3F1000.
    N22Z4.986A-85.7F1000.
    N23X0.A-85.7F1000.
    N24Z5.A-90.F1000.
    N25Z4.986A-94.3F1000.
    N26Z4.996A-102.9F1000.
    N27X20.A-102.9F1000.
    N28Z5.A-111.4F1000.
    N29Z4.992A-120.F1000.
    N30X0.A-120.F1000.
    N31Z4.999A-124.3F1000.
    N32Z4.997A-137.1F1000.
    N33X20.A-137.1F1000.
    N34Z4.999A-145.7F1000.
    N35Z4.987A-154.3F1000.
    N36X0.A-154.3F1000.
    N37Z5.A-158.6F1000.
    N38Z4.996A-167.2F1000.
    N39Z4.997A-171.4F1000.
    N40X20.A-171.4F1000.
    N41Z5.A-180.F1000.
    N42Z4.997A-188.6F1000.
    N43X0.A-188.6F1000.
    N44Z4.986A-194.7F1000.
    N45Z4.987A-205.7F1000.
    N46X20.A-205.7F1000.
    N47Z4.999A-212.1F1000.
    N48Z4.997A-222.9F1000.
    N49X0.A-222.9F1000.
    N50Z4.988A-229.F1000.
    N51Z5.A-237.6F1000.
    N52Z4.992A-240.F1000.
    N53X20.A-240.F1000.
    N54Z4.999A-249.4F1000.
    N55Z4.996A-257.1F1000.
    N56X0.A-257.1F1000.
    N57Z4.989A-263.3F1000.
    N58Z4.999A-271.4F1000.
    N59Z4.986A-274.3F1000.
    N60X20.A-274.3F1000.
    N61Z4.999A-281.7F1000.
    N62Z5.A-291.4F1000.
    N63X0.A-291.4F1000.
    N64Z4.992A-300.F1000.
    N65Z4.978A-308.6F1000.
    N66X20.A-308.6F1000.
    N67Z5.A-315.F1000.
    N68Z4.999A-325.7F1000.
    N69X0.A-325.7F1000.
    N70Z4.981A-331.8F1000.
    N71Z4.987A-334.3F1000.
    N72Z4.985A-342.9F1000.
    N73X20.A-342.9F1000.
    N74Z4.999A-350.4F1000.
    N75Z5.A-360.F1000.
    N76X0.A-360.F1000.
    N77Z13.071A-360.F1875.
    N78 M02;
    Re: rznc-0501 4th (c) lathe axis
    0501 support 3 axis 3linkage , then suggest you take X axis as rotary ,
    Next time ,suggest you choose DSP A18 ,it support 4 axis 4 linkage ,process cylinder wood or square wood.
  1. rznc 0501 3-axis or 4?
    By delid in forum Chinese Machines
    Last Post: 03-16-2019, 07:44 PM
  2. Anyone use RZNC-0501 HBBC usb controller?
    By jeepers94 in forum Chinese Machines
    Last Post: 12-03-2017, 08:52 AM
  3. Differences between DSP RZNC-D5416 and RZNC-0501
    By KDRusty in forum Chinese Machines
    Last Post: 06-04-2014, 10:06 PM
  4. RZNC 0501 Plasma on/off
    By pyrohamish in forum Controller & Computer Solutions
    Last Post: 09-16-2013, 04:42 PM
